Mystery Part
Old Feb 10, 2007 | 02:10 PM
Yogi Bear's Avatar
Default Mystery Part
Had the machine shop clean, bore and hone a 6.0 L block. They returned this mystery part. Can anybody tell us what it is and where it goes?
Old Feb 10, 2007 | 02:26 PM
thunder550's Avatar
High on diesel fumes
Doesn't look like anything I've seen before....you sure it came from your block?
Old Feb 10, 2007 | 02:28 PM
dirt track racer 81's Avatar
looks like an oil restrictor like what i used in my SBC racing engines
Old Feb 10, 2007 | 02:39 PM
Yogi Bear's Avatar
We're as sure as you can be when working with a machine shop. They saved the part in a little box and returned it with the block. I wasn't there to ask them what it was.
Old Feb 10, 2007 | 02:41 PM
Yogi Bear's Avatar
Does a stock 6.0 L have an oil restrictor? If so, where does it go?
Old Feb 10, 2007 | 03:02 PM
no..it might have came out of another engine if it is an oil restrictor
Old Feb 10, 2007 | 03:33 PM
Stoichiometric's Avatar
It goes in behind the rear cover in an oil passage.
Old Feb 10, 2007 | 04:18 PM
Yogi Bear's Avatar
OK! We found a passage on the driver's side that it fits into. Which end goes in first? One end has an o-ring and the other doesn't. And what does this part do? Thanks for the help!
Old Feb 10, 2007 | 04:21 PM
04BlackSilverado's Avatar
Oil passage in the back of the block on the driver's side. It divides the oil passage so the oil flows through the filter and it plugs the back of the main oil galley. It's p/n 12573460 and it sells around $5.
The o-ring goes twards the back of the block
Old Feb 10, 2007 | 04:22 PM
CHEVRACER83's Avatar
It Goes In The Back Between The Rear Plate
