My 03 Denali for massive HP
Old Nov 11, 2008 | 12:09 AM
  #31
trever1t's Avatar
2nd fastest 5.3 ECSB
You buy the cutout...it is a short y off the exhaust. You weld it in...crawl under to remove the plate. YES, you will hear a big difference! You will need to tune for the cutout to see a big difference.
Old Nov 11, 2008 | 03:32 AM
  #32
blizzardx23's Avatar
so that cut out just goes before the muffler? then I take the plate off for more power and sound? then plug it up for what? to smog it or something? Also, would I get two of them? one for each side? seems to me like you'd want each side with an even amount of pressure..
Old Nov 11, 2008 | 03:37 AM
  #33
95 bright teal's Avatar
Place it before the muffler to bypass it
You remove it so it can be crazy loud and flow more.
You can buy electric cutouts which can be opened and closed with the switch in the cab.
I had a DMH in my camaro, it was alot of fun
Old Nov 11, 2008 | 08:54 AM
  #34
So I would get two of them then right? one for each pipe leading into the single muffler?..whats DMH? is it electric? I could put a toggle in the truck to open them up for better flow?
you guys say I have to tune it for a cut out(s)...if I tune it to run with cut outs...will it harm or decrease power when I run the truck with the cut outs closed?
also...with these going on creating a "straight pipe" effect (after cats of course)...could that burn up the valves? (My SGT told me I would burn up the valves when I told him I was going to straight pipe our humvee...)
Old Nov 11, 2008 | 09:27 AM
  #35
trever1t's Avatar
Yes, you would put a switch in if you opted for the electric cutouts. DMH is a brand name.
Your tuning would be 'on' for the cutout...yes, no harm but not spot on with it closed...unless you do like me and have multiple tunes. You'd have to purchase the tuning software your tuner uses and work that out with him.
No harm to the valves, you only need a few inches of head pipe on an engine to prevent vlave warp.
Old Nov 11, 2008 | 01:19 PM
  #36
Sorry Trever, I dont get it =/
what do you mean "but not spot on with it closed"?
If I get the cutouts and install them, Can I run them open and closed without tuning it first? and if I tune later on to work with the cut outs, Can I run them open and closed without changing the tune?
also, you say you have multiple tunes....how do you switch and what for? multiple plug and play ECUs or something?
I do appreciate the help though...thanks =)
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
