milled heads BTR cam combination
Old Dec 30, 2014 | 08:04 PM
needmorepewter00's Avatar
Default milled heads BTR cam combination
Building a stock bottom end LQ4 with a BTR Stage III Truck cam specs are 218/224 .553/.553. It will see some nitrous at the track. I am considering milling the heads (317) .030. I know generally higher compression and nitrous dont mix. Thoughts? Will PTV clearances be okay?
Old Jan 6, 2015 | 05:59 AM
iamkeniff's Avatar
That is a mild enough combo to not worry with a PTV issue
Old Jan 6, 2015 | 07:55 AM
Vortec350ss's Avatar
As mentioned PTV wont be a concern at all.
Old Jan 11, 2015 | 11:14 AM
LS1TRUCKGUY's Avatar
There is no problems with high compression and nitrous. How much do you plan on spraying?
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
lxcoupe
Jul 30, 2015 02:42 PM
USMCvet0311
Jul 29, 2015 01:28 PM
steves86ta
Jul 28, 2015 10:21 AM
