milled 243's on an LQ4
Old Mar 7, 2007 | 03:49 PM
KB's Avatar
KB
13 Second Truck Club
Default milled 243's on an LQ4
I was searching on some older threads and found that you can put stock 243's on an LQ4 and gain a whole point in compression over the 317's. My question is, can you mill the 243's and gain even more compression using the stock LQ4 dished pistons? If so, approx. what would the compression ratio be? Would there be any benefit to this over the 317's, and also will I need different length pushrods?
Any info is appreciated. Thanks!
Old Mar 7, 2007 | 03:52 PM
Quik's Avatar
5 year bitches!
depends on how much you mill. yes a 64.5cc head compared to a 72cc head would net you close to a full point of CR
Old Mar 7, 2007 | 04:07 PM
KB's Avatar
KB
I'm new to all of this so bare with me, but what would be a "safe" amount to mill the heads to without running into clearance problems?
Old Mar 7, 2007 | 04:19 PM
Quik's Avatar
5 year bitches!
well on a LQ4 you would be at 10.5 with 243s, if you would put on a set of 5.3s heads that would take the CR up around 10.9
i think those heads are 61cc
so .015 would get you down to that CC roughtly you can go .030 and take yourself down to 59cc roughly
but for pushrod lenght and etc you would have to check that when assembling motor
gmcyukon
Oct 3, 2015 11:03 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
