MERGED: how much power will.stock lq9 rods hold with arp bolts and good pistons
Old 04-20-2010, 02:21 PM
mushroom281's Avatar
Default MERGED: how much power will.stock lq9 rods hold with arp bolts and good pistons
Im building a lq9 and putting a 70mm on it. And was wondering how much power stock rods will hold. This is in a ws-6 trans am and it will be mostly street some strip looking.g to push 650. To 700 rwhp with Meth.
Old 04-20-2010, 08:06 PM
well upon searching a little.deeper I have found people making 825 on 95k Mile all stock lq9s . So why go with callies rods unless your making 1000 hp
Old 04-21-2010, 03:21 AM
02'Z71ONDUBZ''s Avatar
With that size turbo, I probably wouldn't worry about it. Your likely to run out of air well before those internals give.
Old 04-21-2010, 08:44 AM
FormerVendor
Callies Performance's Avatar
It have heard guys are putting 800 on a stock rotating assembly, but I would recommend changing out the bottom end. I am not sure the exact rating on stock rods.
Old 04-21-2010, 10:18 AM
FormerVendor
Sales2@Texas-speed's Avatar
Agreed, its been done but that doesn't make it a good idea! For inexpensive "insurance" I'd go with a set of Callies Compstar rods and some Wiseco pistons. I can get you into rods and pistons, including a steel top/napeir 2nd ring set, for about $1300. The rods are rated to 900hp with the ARP2000 bolts they come assembled with (conservative IMO, we've pushed them quite a bit farther than that!), and the 2618 forging pistons with that ring set will hold the power you're looking to push and then some!
Let us know if we can help
Old 04-21-2010, 11:31 AM
quicksilverado's Avatar
Cablebandit was at 750 rwhp for about 2 1/2 years with stock rods.
Old 04-21-2010, 11:49 AM
GFYS and STFU
Spoolin's Avatar
If your tune is dead on it will live, but one false move and it's game over for the rotating assembly.
Old 04-21-2010, 07:17 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Please do not cross post!
Old 04-22-2010, 12:53 AM
BadAssChevy327's Avatar
i heard most rods give to rpm, not so much the cylinder pressure from high hp.
Old 04-22-2010, 07:35 AM
well i have come to the conclusion that i think the stock rods will hold the power i want to make with ease . i may want to make more power down the road so i am putting in forged rods also . so matt i iwll be giving you a call
Quick Reply: MERGED: how much power will.stock lq9 rods hold with arp bolts and good pistons
