Melling M295 which o-ring color?
Old Mar 23, 2013 | 04:47 AM
black04's Avatar
Default Melling M295 which o-ring color?
Quick question guys. I am changing the oil pump on an lq9 with a melling m295 (original replacement).
The stock O-ring is red but the pump came with a green and black one. The green is the thicker one. The diagram shows that I should be using the green one but it's really tight in the pump. Should i force it in there or reuse the red one?
Old Mar 23, 2013 | 07:52 AM
Beatdown Z's Avatar
Laid Back
Lube up the green one and wiggle it in there ever so gently. I just installed a green Melling o-ring in my truck. It went in no problem.
Old Mar 23, 2013 | 08:19 PM
Gadgetized's Avatar
Lube the O ring as suggested above. The O ring is determined by the pickup tube. From everything I have read the trucks came with a necked down area where the O ring goes, and the cars are straight. I would use the thicker one, and make sure it seats in properly.
Old Mar 23, 2013 | 09:58 PM
pillittokillit04's Avatar
I used the green one on my install holds great
Old Mar 24, 2013 | 01:12 AM
Atomic's Avatar
I have a gauge for that
Like said, match the oring to the tube not the pump.
Old Mar 24, 2013 | 02:18 PM
black04's Avatar
Thanks guys the green one went in good.
Texas5.3_1251
Mar 5, 2016 08:10 PM
OHsixLS3
Nov 22, 2015 07:45 PM
OHsixLS3
Sep 25, 2015 11:20 AM
RONIN LSX
Sep 19, 2015 05:33 PM
DrX
Sep 18, 2015 08:53 AM
