Max Hp on stock crank?
Old Jan 12, 2015 | 03:19 PM
Rootbeer02's Avatar
Default Max Hp on stock crank?
Interested in what you guys have made or seen power wise on stock cranks. Im using an 05 lq4 block and crank that's fully arp studded. Looking for around 800hp
Old Jan 12, 2015 | 04:31 PM
Moneypitt's Avatar
I am building a 03 LQ4 and everyone I have talked to says they are good up to around 1000hp, I am shooting for 800hp at the crank and 650-700hp at the wheels and am going with the stock crank as long as it checks out. If not then I am going to a 4" stroke crank.
Old Jan 12, 2015 | 04:38 PM
javzh's Avatar
mine put down 825rwhp on mustang dyno. stock bottom end.
Old Jan 12, 2015 | 04:41 PM
custm2500's Avatar
Ph.D. in HUBRIS
Seems like most people run out of money before they run out of stock crank power handling.
Old Jan 12, 2015 | 04:45 PM
Vortec350ss's Avatar
Yea... thats gettin after it alright. No wonder you runt he times you do. Impressive ****.
To add a slight twist to this... I wonder what they are capable of with a supercharger as opposed to a turbo.
The supercharger is much more difficult on it for a few reasons. The first is that a supercharger has parasitic loss, meaning that to make 800 crank HP you need to really be making about 900 (its just a guess, but it works for this illustration). To add to that its an opposite force on the snout of the crank adding a ton of force to that one area. So not only is it the equivalent or a great HP force on the crank, but its an additional reverse rotational force.
Old Jan 12, 2015 | 04:51 PM
George C....'s Avatar
Formerly ScreamingL
i will chime in as ive made over 1000 rwhp with a stock motor
around a 1000 rwhp you start to flex the crank badly and you notice this by oil pressure dropping. this flexing starts to wipe out the mains, typically youll see a drop of 10psi all of a sudden...motor still runs just has lower oil pressure
eventually it will fail
Old Jan 12, 2015 | 05:47 PM
Rootbeer02's Avatar
Yeah eating the main bearings out is something Id like to avoid, 800 to the wheels is a ton in a truck glad to know it will hold together. Last thing I want is to get it in and have to pull it right back out.
Old Jan 13, 2015 | 12:38 PM
black00chev's Avatar
Slowest turbo build ever!
Jarrett(Stock48) would be the man to talk to about this. I think he was pushing well over 800hp at all 4 tires(4WD) on his stock bottom end 6.0L and I think he's doing the same in his Nova.
Old Jan 13, 2015 | 04:46 PM
Formerly ScreamingL
Jarrett and Our Notch's combo isnt far off, weve bounced data back and fourth...we ran similar numbers at track
read up on how the crack flexes over 1000rwhp and see how many ppl drop oil pressure after awhile
Old Jan 13, 2015 | 07:17 PM
Moneypitt's Avatar
So would 800hp at the crank be about the max you would want to go and have it last a while?
