Making some progress getting the 418 back together
#41
Tin Foil Hat Wearin' Fool
I just cant decide on whether to go ahead and get this intake ported and the outside polished, or run it as is and wait till Richard gets done with the L92 program and slap a set of those on with a carb intake and get that one ported and shined up. They would flow about 70CFM better then the 317s
#42
#43
Originally Posted by Rhino79
They might flow better, BUT what about velocity, I am not sure one way or another, but that might be something to consider.
#45
All of those things will be answered here shortly, I dont think the valve reliefs are going to be a problem, atleast I have heard of any problems with it yet. On paper they look like damn good heads so we will just have to see whats in store for us in the next few months. I know one thing, if these heads do work well, 317s arent going to be worht ****
#46
I have an extra set of the 317 paper weights too. Is the deck on the L92 any thicker than a 317? I wonder how the head gaskets will hold up compared to the thicker decked Edelbrock? I originally wanted to go with the L92 head, but at the time when I bought mine, there were not too many in use. I was scared of the offset rocker and the valves not fitting in the dish of my pistons. Is the L92 VicJr already available?
Once you reach a certain power level, things like O-ringing the heads become more of a priority than more CFM.
#47
GM makes a carb intake and someone else but not edelbrock. The edlebrock 245s you have will be a much mroe stout setup and keep headgaskets alive alot longer. I want a 10.80 at full street weight, Im hoping this setup and and 15#s will be enough, Im ready to move on to something else.
#49
Originally Posted by FarmerBeau
Just out of curiosity. Did you have/need/want to change your ring gap due to you going FI? Would it make much difference if you didnt change it?
#50
, As far as the L92's, you'd probably need a set of pistons with the valve reliefs in the correct spots and correct size for those monsterous valves too.
