Making some progress getting the 418 back together
Old Dec 12, 2006 | 07:45 AM
  #31
thunder550's Avatar
High on diesel fumes
I'm talking the full LS2 timing set, with cam gear and crank gear.
Old Dec 12, 2006 | 07:39 PM
  #32
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Timing chain cover is going to have to be clearanced. The bolts on the oil pump is what is hitting the t-chain cover. I realize the gasket will take up most of the space shown but Im not comfortable with those bolts being so close or rubbing the cover.
Old Dec 12, 2006 | 07:58 PM
  #33
thunder550's Avatar
Have you thought about grinding down the head on the bolts at all?
Old Dec 12, 2006 | 07:59 PM
  #34
1slow01Z71's Avatar
I could do that bit it would make it harder to take the pump apart and it wont take but about 20 min with my air grinder, I may knock some of the ridge off my oil pump bolts too. It wont take but maybe 200 thousandths to get it to clear totally.
Old Dec 12, 2006 | 08:15 PM
  #35
Quik's Avatar
5 year bitches!
thats odd cause i used the rollmaster a few times and never once an issue
Old Dec 12, 2006 | 08:21 PM
  #36
1slow01Z71's Avatar
Did your kit come with the aluminum spacers and longer bolts?
Old Dec 12, 2006 | 08:26 PM
  #37
Quik's Avatar
5 year bitches!
my kit came with aluminum spacers to space the oil pump along with matching bolts
Old Dec 13, 2006 | 08:34 PM
  #38
1slow01Z71's Avatar
Ended up just grinding the heads on the bolts of the oil pump cover down some and it is going to clear just fine now, pretty easy fix for once
Got the oil pump on, head studs in, side ARP main bolts in, head gaskets and heads sitting on there, tomorrow night Ill be tq'ing them down.
Just a little teaser of what awaits for the intake side of it
Old Dec 13, 2006 | 08:45 PM
  #39
Rhino79's Avatar
9 Second Club
Looks good!
Old Dec 13, 2006 | 09:49 PM
  #40
Stoichiometric's Avatar
Your teaser worked, that looks badass. I think any restriction in your intake track has been minimized. . Good work.
