Lunati black magic cams
Old Dec 24, 2020 | 09:25 PM
rick539's Avatar
Default Lunati black magic cams
Was researching the new lunati black magic cam series. Wondering if anyone has some comment on them. Looks budget friendly. Here is their stage 3 cam which is the truck cam.
Installed in a stock 5.7 LS1, this cam was good for over 370 RWHP. Designed for the truck owners with top end power in mind, a 3000-3200 RPM torque converter is required to ensure good idle and drivability characteristics. Advertised Duration IN/EX: 276/285; Duration @ .050" IN/EX 224/230; Valve Lift IN/EX: .553"/.547"; LSA/ICL: 111/109
Sales pitch : Lunati's Black Magic series offers incredible power at a great price that won't break the bank. These proven lobe designs ensure reliability while still making great power and sound. Lunati's in-house all black surface finish adds durability, hardness and surface area to the cams, as well as a unique and awesome look. The finish remains intact after initial break-in and aids in identifying the "surface ride" area of the cam while the cam "stages" simplify the selection process for your specific performance goals. Black Magic Camshafts are an excellent choice for a wide range of GM LS performance applications. Only "black magic" can provide this kind of power at this price.
comments ?
Old Dec 24, 2020 | 09:50 PM
arthursc2's Avatar
That duration is HUGE!! I have a 408 with less duration lmao
Old Dec 25, 2020 | 02:55 AM
1FastBrick's Avatar
Custm2500's Rude Friend
What are you wanting to put this in and what is your goal with it???
I believe this line of cams is fairly new to the market.
FWIW, You can get a texas speed low lift cam for $299
Old Dec 25, 2020 | 07:35 AM
rick539's Avatar
I was just curious what people thought. I’m thinking of getting the Summit Stage 4 (8714) with supporting springs. Setup is:
06 single cab stepside. Weight a little over 4000 lbs
6.0 with 706 heads SCR a tad over 10.5:1
long tube headers
3000-3200 stall
4.10 posi trutrack
not a daily driver, just a get in trouble on the weekend truck.
Old Dec 25, 2020 | 08:37 AM
madmann26's Avatar
That looks like the Sloppy Stage 2 or even the Summit turbo cam.
224/230 isn’t huge but having a good converter will make it fun.
Old Dec 25, 2020 | 09:32 AM
arthursc2's Avatar
What's the 276/285 then? Duration at .006? That's what's huge
Old Dec 25, 2020 | 09:34 AM
madmann26's Avatar
More then likely that is the .005/.006 numbers.
.050 is “normal” numbers.
Old Dec 25, 2020 | 09:43 AM
arthursc2's Avatar
Ah, well I re-read it and yeah he states right under where I got confused "224/230". Not that big for a 5.7/6.0
carry on, make power. Let's gooooo
Old Dec 25, 2020 | 01:44 PM
RedXray's Avatar
100% Redneck
Very close to the SS2.
Between the Summit 8714... I'd pick the Sloppy for the extra (.585") lift and better price. The extra in savings with the SS2 could go toward a set of PAC-1218 .600" springs and be right at the same cost of the 8714 cam & LS6 springs.
Old Dec 25, 2020 | 02:05 PM
rick539's Avatar
I was also looking at Cam Motions ls hotrod cam under their truck cam section. Can’t find much on it. Duration at .050: 227/237
111 Lobe Center Angle with a 107 Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .595"/.587"
