LS6 springs: Blue vs. Yellow
Old Jul 26, 2006 | 05:04 PM
vanillagorilla's Avatar
Default LS6 springs: Blue vs. Yellow
I have an 02-up LS6 cam on the way that specs at 0.550" lift at the valve with 1.7 rockers. Currently I have LS6 springs in my engine, but they're the blue ones that come with the hot cam kit or that cam on 01 LS6's. I'm wondering if I can get away with the blue LS6 springs with an 02 LS6 cam. Does anyone know the difference between the two different LS6 springs?
Remember I have FI and I'm not affraid to spin the mighty 4.8 to 6500.
Old Jul 26, 2006 | 06:08 PM
budhayes3's Avatar
PT's Slowest Truck
From what I've read, the yellow ones are supposed to be rated for higher lift than the blue ones. SDPC had the yellow ones as a set for around $60 shipped, that's where I got mine Not sure if the blue ones are OK for the 02 LS6 cam though...sorry
Old Jul 26, 2006 | 09:57 PM
REDWS6ROCKET's Avatar
all the springs i have seen with a blue stripe are the 918's?
Old Jul 27, 2006 | 01:13 AM
im pretty sure you can use the blue ones. i had the 02 LS6 cam or whatever one has .550 lift and i used my stock springs and it worked just fine
Old Jul 27, 2006 | 10:43 AM
So no one has any hard concrete advise or experience as to whether or not I should do this? I'm going to check the coil bind to be sure, but I doubt it will at 0.550" lift.
Old Jul 27, 2006 | 11:55 AM
Last Call's Avatar
TOTM: January 2007
'01 springs .540 / 250lbs - blue
'02 springs .600 / 300lbs - yellow
Old Jul 27, 2006 | 12:37 PM
ktmrider's Avatar
I had some blue springs seat and coil bind tested when installing on a set of #243 LS1 heads. It would have been VERY close to coil bind with the 02+ LS6 cam lift of 0.550", close enough that the machine shop recommended shaving the seat pocket to be sure. I later realized I sent the 02+ cam specs, not the 01 Z06 cam that I had.
BTW the 01 Z06 cam was rated at 0.525" lift.
Old Jul 27, 2006 | 04:18 PM
That's the kind of info I need. The fact that the blue's aren't even rated at .550" makes me think they're inadequate. I'm sure as hell not shaving spring pockets either! Looks like I'm going to buy a set.
Does anyone know what shims I should use? What's the installed height?
Old Jul 27, 2006 | 05:07 PM
ktmrider's Avatar
Shim wise the LSx heads use a combo shim/valve seal. You can increase the pressure with discs under the cap but if too high ( could cause lifter bounce or excessive valvetrain wear ) you need to shave the pocket.
Sorry but I don't have the height specs. Maybe Richard/Big Tex?!?
Old Jul 27, 2006 | 08:21 PM
TIM Z's Avatar
11 sec. Truck Mod
i have the yellow springs and the way they are installed if i remeber correctly was just took the old springs out and pop in the new. I too like to wind my truck out to 6500.
