ls6 intake manifold?
Old Sep 11, 2008 | 03:19 PM
FL.04GMC's Avatar
Default ls6 intake manifold?
i have 5.3 motor and was wondering if i could swap the truck manifold with any of the ls6 manifolds like the fast lsx, or factory 5.7-6.0 manifolds? didnt know if there would be any port matching issues with the 5.3 heads or if they would be a direct bolt on with the 5.3. any help would be great
Old Sep 11, 2008 | 03:33 PM
FL.04GMC's Avatar
found what i was looking for. now for the next question. is their anything to gain from this swap on engine with full bolt ons and 212/218 cam besides getting rid of the hidious truck manifold?
Old Sep 11, 2008 | 03:46 PM
sickREDsierra's Avatar
PM TXsilverado... he did that exact swap, and didnt gain much the first time out to the track, after a full retune. i think he gained maybe 1-2 mph and a hundreth of a second
Old Sep 11, 2008 | 04:46 PM
Raffman's Avatar
Your're only going to gain in the upper RPM's
You will have to change the waterpump to the L92, relocate the idler pulley and trim the alt/ps pump bracket. Also depending on injectors you might have to space them. .............You gotta want it!
Old Sep 11, 2008 | 05:28 PM
skyhighsami's Avatar
no title here
I think from everything that I have read that the truck manifolds are just as good as the LS6 if not better for the rpm range and powerband the truck needs. They do look ALOT better though
Old Sep 12, 2008 | 11:19 AM
TXsilverado's Avatar
i have the same view until it proves itself to me. the truck intake is under-rated by everyone IMO.
Old Sep 12, 2008 | 12:15 PM
zippy's Avatar
I think there is a little bit to be gained with the LS6 intake. I think that for the cost of the swap though I'd just get one of the new style truck intakes which flow better and use a bigger throttle body.
Old Sep 12, 2008 | 12:28 PM
no title here
Yeah because with the newer truck style that have a 90 mm opening I think then you could get an aftermarket TB and use the extra area the newer style intake provides. Right?
Old Sep 12, 2008 | 02:57 PM
12secSS's Avatar
Absolutely! The key is the intended rpm range, unlike a passenger car that needs upper rpms. The LS6 is definately better then the truck intake, but the truck intake is better then the LS1. The LS6 will shine on upper rpms (+4000rpms), not what a (street) truck needs.
Old Sep 13, 2008 | 12:59 AM
from my experience so far...truck intake=ls6 intake. shifte same rpm on both intakes within a week and pulled the same times on track both times. maybe the cool weather will let it shine....hopefully
in the end. MONEY IS BETTER SPENT ELSEWHERE
