ls6 intake manifold?
i honestly dont think that was a good comparison between the two intakes since the gains will be in the 1/4
thx for the help with the intake ?'s. with whats been said ill prob stick with the truck intake or maybe upgrade to the new truck intake with the 90mm tb. im really looking to gain more power on the bottom end. trucks current mods are dynatech lt's, high flow cats, borla exhaust, cai, comp cams 212/218 115lsa, and dyno tune. what mod should be my next step in building a little more bottom end power?
well your not going to gain a whole lot if any in the 1/8th with the LS6 vs the truck. like stated above it shines better on top end than taking off the line. im not sure on my 1/8th times but i did gain 2 tenths and 2mph with mine over the LS1 intake in the 1/4.
also you switched from ls1 to ls6 so you had more power to gain on the table than going from the truck to ls6.
as far as milling the heads is concerned, if i knocked .030-.040 off the heads wouldnt i have to modify the intake manifold as well? does the composite manifold have o-ring seals or regular gaskets? if it has o-ring seal how would i be able to modify the manifold to fit heads? would i need to cut o-ring grooves back into manifold or are they on the heads?
