ls6 heads on 5.3
Old Aug 21, 2008 | 09:47 PM
lactruck's Avatar
Default ls6 heads on 5.3
Found a deal on a set of ls6 heads with a polished weiand intake. Truck already has headers, small cam, 125 shot, 2800 stall and a tune. I was just curious if it would be worth the swap to put this stuff on. So far the truck has gone 8.0s with steet tires on the spray. Looking to go a little faster
Old Aug 21, 2008 | 09:52 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Welcome to PT.net
243 castings?
Your year 5.3?
Unless you mill the heads a bit you will lose CR and bottom end torque. You could always sell them and make a $ if you don't use them.
v8
17,16,15,14,13,12,11 Drvr
Waste of time, use the search on the top right corner!!
search weiand and you will see how it worked and what it took to install it under my screen name.
Old Aug 21, 2008 | 09:57 PM
lactruck's Avatar
Originally Posted by trever1t
Welcome to PT.net
243 castings?
Your year 5.3?
Its a 05 gmc. The heads are already milled. Im just curious if its gonna be worth the headache of doing it or if I should just leave it alone and find power somewhere else
Old Aug 21, 2008 | 09:59 PM
trever1t's Avatar
05 GMC....what model? (The ECSB Z71 came with the L33 Alumium block and 799/243 heads factory.)
Old Aug 21, 2008 | 10:01 PM
lactruck's Avatar
Its just a regular cab shortbed sierra. Its a regency truck if that makes a difference
Old Jan 6, 2009 | 10:41 PM
frankenstein2's Avatar
Registered User
I've installed a set of 06 243 heads on my 2000 5.3L silverado with 04 z06 cam no tune yet but yes it's a dog out the hole once it gets to 3000 rpm's it comes alive.No cats with 2.5 dual pipes into 2 in and 2out super 40 serie flowmaster no headers either i've just done this last week and still trying different things.
Old Jan 6, 2009 | 10:43 PM
Registered User
from a 15-20mph roll it spins tires for about 2 1/2 blocks looking for shorty headers.
Old Jan 6, 2009 | 10:50 PM
GMCtrk's Avatar
Yes, the heads should make a nice gain. Stock 5.3 heads are 61cc I believe. I'd mill down the 243s as much as possible to get your compression to stock levels or higher.
Old Jan 6, 2009 | 11:01 PM
Registered User
what would you guys think if i super charged it?
