ls6 cts-v cam ??'s
Old Jun 23, 2008 | 07:05 PM
TURBHOE's Avatar
Default ls6 cts-v cam ??'s
so i read on ls1tech that the cam specs were the same between the vette ls6 and the cts-v ls6. but what are the specs for a 05 ls6 cts-v? and where is the cam sensor? is it on the back like my 04 tahoe or is it on the front like the ls2's?
is it the 204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Old Jun 24, 2008 | 09:30 AM
hirdlej's Avatar
All LS6's had the cam sensor in the back, if the 05 CTS-V has a LS6 then the cam will work fine with your tahoe
Old Jun 25, 2008 | 08:29 AM
TURBHOE's Avatar
thanks, i was just wanting to make sure. the later ls6 cams are suppose to be good turbo cams. so if its the same i'll be good to go.
terravast4
Aug 12, 2015 02:07 PM
darnie
Aug 10, 2015 10:25 AM
Jake99
Aug 8, 2015 07:56 AM
Blackrat48
Aug 4, 2015 09:52 AM
Aboss
Jul 9, 2015 10:28 AM
