ls1 hotcam
Old Mar 6, 2008 | 12:21 AM
  #21
Wheatley's Avatar
Truck Sponsor
There are much better cams out there
Old Mar 6, 2008 | 12:25 AM
  #22
Wheatley's Avatar
Truck Sponsor
The 212/218 is a great cam
Originally Posted by cwalker2006
and for the tb converter do i get the ss one or the 6 cylinder one and where. i was thinking of the 212/218 some 7.4 comp pushrods and some springs.
Old Mar 6, 2008 | 12:47 AM
  #23
InchUp's Avatar
Originally Posted by RandomHero
Also, I hate to break it to you, but the ls1 intake will hurt performance over the truck intake and true duals are a bit excessive.
I told him the LS1 intake wouldn't increase flow much but it's the room he's worried about. The truck is body dropped and a truck manifold doesn't fit. He got the LS1 intake for $10 bucks on ebay and it fits. Anything is better than a 200k mile 4.3L all iron V6, so it'll do. Plus, true duals are never excessive. All one needs to do is determine where they want peak torque at, then start bending the correct pipe size with some form of a pressure equalizer between the two.
why do people insist on the hot cam? There is nothing special about it. It's just GM's performance cam offering. You can get any cam you want from comp for $400.
He can get one for under $200, that's why.
Old Mar 6, 2008 | 07:48 AM
  #24
onebadrubi's Avatar
The hot cam was designed to be easy on valvetrain. It has low ramp rates and not excessive lobes to wear the springs bad.
Old Mar 6, 2008 | 08:25 AM
  #25
jakebdb56's Avatar
That's one of the reasons I went ahead and did this cam because I don't want to worry about drivetrain wear any time soon, although heads are in the near future now. Another reasoning is if a GMPP engineer designed this cam for their LSx motors to be a street performance cam it's going to get its full potential for it's dimensions. I would rather have gone with a TR224 probably, but didn't want that much lift. In a nutshell, a lot of people are against this cam but it makes great power across the board. I'll have new dyno numbers on spring break once the new tranny is in.
If your buddy is building the motor to rev high why not get a bigger cam that will kill up top? Seems kind of pointless to get a sub-220 cam with a low LSA for a high revving motor. Since it's a sport truck I'd go wild with it.
Old Mar 6, 2008 | 09:19 PM
  #26
hijacker1's Avatar
Registered User
what the
Old Mar 6, 2008 | 10:33 PM
  #27
one03sierra's Avatar
Formerly one92rs
Talking
comp 216-220 is a good cam to go with on a low stall. i had it in my old chevy and it worked great,. that was with the factory verter stalled to 2400 and a good tune. and it was my belief that the ls6 springs werent any good with cams over the 550 lift. if you are going to go thru the trouble and maybe make a swap later i would go with the 918 springs and do it once.
Old Mar 9, 2008 | 08:52 PM
  #28
mcfarlnd's Avatar
Un-Registered User
the hot cam is to big for you!
People need to calm down on these huge cams. Elaborate on what you are wanting. If you want a snappy throttle with just more low end and al ittle more top end I woud look at a custom grind in the area of 208/212 or 210/212. Great for torque, anything bigger will only pull torque into your higher rpms and create more HP at 4500 + rpms.
what if you install the larger cam +4. wouldnt that bring the rpm range down?
Old Mar 16, 2008 | 10:40 AM
  #29
mred's Avatar
why would people not like it. i ran a lt4 hot cam in my older truck and i loved it,for everyday driving. i would like to know what is better myself?
i agree^^^^
i myself was thinking of using the hot cam myself,people say its a good cam but there is better, which i agree.
but?
running a 212-218 how much lift is to much on a stock 5.3 no head work no springs.
or do i gotta do some springs and push rods with a cam as mentioned above?
my truck is a daily driver in dallas,tx and its a 97 swb 5.7
fixing to convert to the 5.3 but i wanna do a cam swap first while its out.
so i dont want to damn radical because i have to a bit of driving.
thats why i was thinking of using the hot cam myself.
so whats your thoughts.
thanks
Ed
Old Mar 17, 2008 | 12:13 AM
  #30
jakebdb56's Avatar
i agree^^^^
but?
thanks
Ed
I like my cam because it's exactly what I was shooting for. A lower lift cam with shorter LSA and good duration. I knew that I would be killing low end with this cam, but a torque converter was a definite plan for the future.
IIRC, Charlie's cam is low lift somewhere in the range of the hot cam's lift around .550'ish? You still should change the springs, and if you want peace of mind I would change the pushrods as well. They weren't "required" for the hot cam, but I run the motor to 6200 and don't want to even think about the stock pushrods failing.
If you daily drive the truck the smaller cam would probably be wise, but if you want to put in a higher stall the hot cam would most likely be quicker.
