ls1 heads
Old Dec 29, 2010 | 05:32 PM
jeffrm's Avatar
Default ls1 heads
will ls1 heads work on my 5.3 i got a set and id like to put em on if they will help any tips on how to do this and will i see any difference
Old Dec 29, 2010 | 05:39 PM
Will they work? Definitely. Which heads are they? I'm gonna do the same soon. I'm going with 241 heads only Cuzz I have two broken exhaust bolts in my current heads and wanna blow my trucks up every time I start it Cuzz the annoying leak.
Old Dec 29, 2010 | 05:42 PM
jeffrm's Avatar
im not 100% sure what kind all i know is they are stock ls1 heads and i really wanna know if ill see a difference in my truck
Old Dec 29, 2010 | 05:56 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
they will fit and they will drop your compression ratio and not breath any better. If you find some 243's or 799 castings and mill them down to keep at least stock CR you'll do fine. Otherwise SKIP it.
Have you guys tried the search feature? There must be over 100 threads regarding heads and 5.3L engines.
Old Dec 29, 2010 | 05:59 PM
1_fastsilverado's Avatar
I found this link for you. They have 66cc chambers vs. your 61cc chambers in the truck heads so your compression will go down and they both flow the same so I wouldn't do it. If you want to do heads I'd find a set of 243's and get them milled or run thinner gaskets to get compression back up. Hope this helps.
https://www.performancetrucks.net/fo...d.php?t=442909
Old Dec 29, 2010 | 06:25 PM
trever1t's Avatar
axekick
Sep 7, 2015 07:01 PM
nrmskate
Aug 11, 2015 02:44 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Denali08
Aug 9, 2015 04:34 PM
Black-Syde
Jul 6, 2015 02:12 PM
