ls1 or 5.3 heads?
Old Mar 18, 2006 | 02:31 AM
WillPewter2000's Avatar
Default ls1 or 5.3 heads?
Which would be beeter of in place of my cast iron 6.0 heads? This will be on a cammed 6.0.
Old Mar 18, 2006 | 08:30 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Why not go with 317s? Awesome heads, even in stock form.
Old Mar 18, 2006 | 11:15 PM
Former Vendor
A set of 5.3L heads (62cc chambers) are going to bump your compression ratio up by over a full point. This could cause problems if you plan on doing any towing. As mentioned, the 317 6.0L castings would be a good choice because you could keep your stock compression ratio (or raise it a little more by shaving the heads), have an aluminum casting, and have a set of heads that will move some air! The 317 castings flow some nice air just out of the box, but you could REALLY step it up with a ported set:
Trevor
Texas Speed & Performance
Old Mar 19, 2006 | 02:44 AM
I don't have the aluminum version though I have the iron set. My motor is a 99-00. Would I be better off milling these down a little or going with the ls1?
Old Mar 19, 2006 | 08:51 AM
I AM A MOTHERF*CKER
You can pick up 317s for a couple hundred bucks, or can get a nice p&p set for $1200-2000.
Denali08
Aug 9, 2015 04:34 PM
vmaxpro
Aug 4, 2015 07:02 AM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
Black-Syde
Jul 6, 2015 02:12 PM
