ls heads
Old Aug 11, 2005 | 11:09 AM
Kano's Avatar
Default ls heads
anyone have a link or info on LS heads
like valve size
combustion chamber size
port sizes etc
5.3- ls1- ls6- 317 all stock, comparing each?
Old Aug 11, 2005 | 01:07 PM
1slow4.8's Avatar
-1997+ 5.7 ls1 heads;66.67cc,200cc intake vol.,70cc exh.vol.,2.00 intake valve,1.55exh.valve
-2001+5.7 ls6;64.45cc,210cc intake vol.,75ccexh.vol.,2.00 intake valve,1.55exhaust valve
-1999+ 4.8/5.3 lr4/lm7;61.15cc,200cc int.vol.,70cc exh.vol.,1.89intake valve,1.55 exhaust valve
-1999-2000 lq46.0;71.06cc,210cc intake vol.,75cc exh. vol.,2.00 intake valve,1.55 exh. valve. cast iron head
-2001+lq4 6.0; same as above except head is aluminum
-2002+lq9;71.06cc,210cc intake vol.,75cc exh. vol.,2.00 intake valve,1.55 exh. valve.
Old Aug 11, 2005 | 01:09 PM
Sport Side's Avatar
http://www.smokemup.com/tech/ls1.php
Old Aug 11, 2005 | 04:22 PM
Kano's Avatar
Okie5.3 PMd me that link around lunch
thanks for the help guys
whats the CR with a set of 5.3 heads on a
LQ4?
If someone has that readily available.
Old Aug 11, 2005 | 07:10 PM
02sierraz71_5.3's Avatar
bill I got will handzels book on hipower gen 3's Ill let you borrow it got all the stock info you need plus I got a build spec sheet on the 5.3
Old Aug 14, 2005 | 08:39 AM
speedz06's Avatar
GMHTP or Superchevy or one of those did a very indepth article comparing these heads--it was this year,anyone know? I will see if I can find it for you.Todd
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
