LQ9 Single Cab Build
Old Jan 26, 2014 | 11:56 PM
sam72104's Avatar
Default LQ9 Single Cab Build
hows it goin guys? I have a 06 Silverado single cab that ill be doing a motor swap on in the next month. I have a few parts already. but need to decide on cam an upper intake or any parts you guys might think I need. if you post parts please send links. this isn't a daily driver but I want the best cam possible regardless the drivability
LQ9 went thru all new bearings and rings - completed
thinking a mega death cam - don't have yet
short runner upper intake - don't have yet
injectors - don't have yet
150 shot???
ls7 lifters - done
double roller timing chain - done
660 lift springs - done
243 heads p&p milled .015's - done
3600 stall - done
performabuilt lvl 2 tranny - done
4.10's Detroit locker - done
suggestions would be appreciated! and any input will also be! thanks
Old Jan 26, 2014 | 11:59 PM
sam72104's Avatar
this truck sees the track, street racing and car shows. might be helpful on yalls opinions!
Old Jan 27, 2014 | 10:07 AM
53bowtie's Avatar
Dont really have any input to give but will be watching for replies as I am building an 02 rcsb with an Lq9 as well. And what part of Arkansas are you from? Im originally from the Fort Smith area and graduated from UofA.
Old Jan 28, 2014 | 10:27 AM
roland1's Avatar
Your build should be good. What compression will you be at? I'm at 10.8:1 with a forged LQ9 and 5.3 heads which are 799 castings...64cc. I think they may be similar to hours but yours are milled.
And I'm running a 226/232. 578/.587 112+3 Howards cam.
Im also turbocharged so our setup will be a bit different.
I still have some tuning stuff to figure out and I haven't driven in other cammed cars so I can't compare cams but I like mine.
None the less good luck with your build. Your on the right track.
1bad2k
Aug 18, 2015 09:50 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Mark_k
Jul 22, 2015 05:37 PM
Aboss
Jul 9, 2015 10:28 AM
supersportsteve
Jul 4, 2015 12:02 PM
