lq9 short block limits
Old Mar 30, 2016 | 09:39 PM
LPCWS6's Avatar
Default lq9 short block limits
I got 2005 turbod lq9 running 14 psi of boost. It's got ported heads. Isky 218 cam, and Pro Flow intake. Runs on 91 pump gas plus 100% meth. It made 708rwhp on the dyno about a 1 1/2 years ago. I was thinking about throwing a little more boost at it and was wondering how more it will probably take before she blows. I'm already over 100k miles it.
Old Mar 30, 2016 | 09:54 PM
FFDP's Avatar
I'd say you are near the limits of the stock bottem end. I've always read somewhere around 700-800whp.
Old Mar 30, 2016 | 10:47 PM
GMCtrk's Avatar
wrong
Old Mar 31, 2016 | 12:09 AM
LPCWS6's Avatar
Originally Posted by GMCtrk
wrong
That's very insightful!
Old Mar 31, 2016 | 12:30 AM
GMCtrk's Avatar
Very few on this site have touched the true limit of a sbe. Stock48 is one.
Assuming 20% drivetrain loss ive pushed 1140 hp thru a stock lq9. Ive got a pile of track timeslips and a couple pounds of rubber on my bedsides to back it up.
Ethanol, 160-170 deg ECTs,.75 lambda, and 13.5-15*
Old Mar 31, 2016 | 12:57 AM
X_Racing1's Avatar
hero!
Old Mar 31, 2016 | 03:21 PM
FFDP's Avatar
Do LQ9's run GEN 4 rods??
Because it seems that GEN 3 rods are known to bend at or near the horsepower this guy is running.
Around 2-3 minutes he shows the bent rods.
Old Mar 31, 2016 | 03:25 PM
George C....'s Avatar
Formerly ScreamingL
Lq9 is first motor to have strong rods
Ive made close to 1100 rwhp on strong rod motor and probably one of highest rpm turning combo
But if tune is wrong any number will cause it to fail.
.now ive recently had a old motor ive pushed hard torn down and saw main caps walked badly around 900 rwhp
Also over 1000 that stock crank will flex like a bitch
So 700-850 should live a solid life
Old Mar 31, 2016 | 03:48 PM
GMCtrk's Avatar
Weight also plays a big role. Georges setup was in a lightweight. Also dyno # means little to nothing about how it will hold up. It could make 900 dyno then load it up in the 1/4 it can scatter
Old Mar 31, 2016 | 04:45 PM
About20ninj45's Avatar
Correct me if im wrong, but didnt the 04 and up lq4 have stronger rods as well?
