LQ9 with 243s
Old Dec 1, 2015 | 07:09 AM
George C....'s Avatar
Formerly ScreamingL
243s on a lq9 will put ya 11.0 now
How much do ya want to shoot for
Old Dec 1, 2015 | 10:19 AM
vortecyota's Avatar
I'd say as much as possible without spending money on domed Pistons or any other machine work other than head milling.
Old Dec 1, 2015 | 10:21 AM
Formerly ScreamingL
Then run them unmilled IMHO
11.0 is fine
Old Dec 1, 2015 | 11:07 AM
vortecyota's Avatar
Enlighten me, why do you say that? You're saying leave a cheap compression bump on the table (mill and thin gaskets)?
Old Dec 1, 2015 | 12:18 PM
Wolftrk99's Avatar
How mych compression do you want mych more than 11:1 youll be into race fuel territory.... The combustionchambers are smaller on 243s to bump compression...
Old Dec 1, 2015 | 12:33 PM
vortecyota's Avatar
How about e85? I only run it a few times a year so if I need race fuel, so be it.
Old Dec 1, 2015 | 12:34 PM
Wolftrk99's Avatar
I would just be concerned with ptv with flat tops and milled heads.... Run thinner head gaskets and youll probably be where you want to be
Old Dec 1, 2015 | 12:46 PM
wretched73's Avatar
My assumption would be that the cost to mill the heads and replace the head gaskets are not worth the gains you will see.
Old Dec 1, 2015 | 02:53 PM
vortecyota's Avatar
The engine is disassembled. Its getting honed, rings and bearings. I'm buying the heads from a friend and they are already at the machine shop we both use. They will at least get milled flat so i figure why not take off a safe amount while we're at it for even more of a CR bump? Gotta buy gaskets either way. Once I make a decision on the whole CR deal, I'll move on to the cam/ springs and pushrods. Then figure which intake to run and build the headers.
Old Dec 1, 2015 | 06:20 PM
Wolftrk99's Avatar
Id just mill them flat and put the thinner gaskets on it and call it a day you should be somewhere in the 11.5-12:1 range with that.... And then probably somehwere in 560-580 lift on cam would be about it for lift without putting ptv waAaay close at higher rpm....
