LQ4 for LS1? Anyone want to trade?
Old Feb 2, 2007 | 04:13 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Top Secrret,
I know that you don't mean any disrespect. I don't mean to put a damper on your spirits either. I'm just indirectly doing some parenting/mentoring from a distance by holding up a caution sign. You might do the same with someone else a few years from now.
All my best,
Steve
Edit:
BTW, I saw your 240Z you posted on the other thread you started. Nice car! It brought back good memories.
Old Feb 2, 2007 | 04:26 PM
Top Secret's Avatar
Originally Posted by j's01silverado
The gen 1/3 engines do not have overhead cams.
I know, but after changing the head gasket on a DOHC, I swear to god I will never touch one again.
Originally Posted by Steve Bryant
Top Secrret,
In that case, I thank you for your mentoring. Without people like you I wouldn't know what the hell I am doing. Sorry for lashing out at out you before. Did you ever have a Z car?
Old Feb 2, 2007 | 06:11 PM
LS1 Tech Veteran
TS,
Yes, I owned a 240Z from 1972 until 1986 https://ls1tech.com/forums/showpost....17&postcount=9.
I'm currently building a 408 Stroker for my truck. I've also helped friends back in the day do conversions:
1. Installing a SBC 283 in a Henry J.
2. Installing a Volvo Engine and Transmission in a MG TD.
3. Rebuilding a 401 Buick Engine, adding a marine conversion package and installing it in an antique Chris Craft boat.
4. Re-engined a number of tractors (as in semi-sized tractor-trailers) with improved power trains.
Steve
PS
Regardless of the outcome of your project, you'll learn a lot and I sincerely wish you well.
Steve
Old Feb 2, 2007 | 06:34 PM
Top Secret's Avatar
Ah, to answer your question when comparing the weight of the stock 2.4 vs a T-56 and LQ4, I have some interesting information:
People on www.hybridz.org have found that after swapping out the stock 2.4 and 4 speed to an LS1/T-56 that they, on average, LOST about a hundred pounds from the car! (I was shocked, and still am)
Seeing that an LQ4 is somewhere in the ball park of 80 pounds heavier than an LS1, and that I will be using a aluminum square intake (No doubt another twenty pounds), my final weight will be within ten to twenty pounds of the original engine and transmission. Less or more, I am not yet sure. But it will certainly be interesting to find out. =)
wickedRCSB
Oct 10, 2015 09:29 PM
slimchevy2
Oct 4, 2015 08:02 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Slammed silverado
Sep 28, 2015 06:14 PM
