LQ4 help
Old Dec 20, 2009 | 06:00 PM
05gmc's Avatar
Default LQ4 help
i put some ls2 rods and pistons in my lq4 block with a 5.3 crank are the pistons suppose to hit the head with out the head gasket
Old Dec 20, 2009 | 06:20 PM
hirdlej's Avatar
Yes, ls motors all have pistons that protrude from the deck surface of the block. That's why you don't want to run too thin of a head gasket as you risk the piston hitting the head at high RPM's as the rod stretches slightly.
Old Dec 20, 2009 | 06:22 PM
05gmc's Avatar
so stock head gasket .051 should be fine
Old Dec 20, 2009 | 08:06 PM
hirdlej's Avatar
Measure your piston to deck height, then choose your gasket from there for optimal quench/compression.
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
