LQ4 cam tr220 or tr224? other?
Old Dec 2, 2006 | 11:39 AM
Black02Z71's Avatar
Default LQ4 cam tr220 or tr224? other?
We just put a 03 LQ4 in my buddys 2000 reg cab step side, and now I'm searching for the best cam for it.
I was thinking TR224 or TR220, or comp 216/220, leaning towards TR220 on 112.
I have a comp 212/218 in my LQ4, buts its a little small, but tons of torque down low. So I'm thinking bigger, but don't want to lose too much below 2000rpm. His truck is a lot lighter so torque loss may not be as noticeable.
-This truck is used to tow
-It will also have to pass emissions test
-Don't want to lose too much fuel mileage
Mods are
-stock LQ4 6.0L
-trailblazer TC 2600rpm
- 02 PCM - hptuners tuning
- Magnaflow exhaust
Old Dec 2, 2006 | 11:46 AM
Black02Z71's Avatar
BTW we did some Gtech runs
5.3L all stock + tuning + exhaust 15.3 at 89mph no wheel spin
stock 6.0L + TB stall + exhaust = 14.4 at 98mph, spinning half way through 1st gear, with half asses tune
Old Dec 2, 2006 | 12:47 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I've had Comp's 216/220 (114lsa), and just swapped to Comp's 224/224 w/ higher lift (.568/.568). I was looking for a good low-end torque cam with the 3K stall TC I have. Since you have a TB 2600-stall TC, the 224 will work as well as all your choices. The TR224's range is 1700-6600 RPM (check their website).
Old Dec 2, 2006 | 02:59 PM
bluecajun5.3's Avatar
11 Second Truck Club
go with the 220
Old Dec 4, 2006 | 08:38 PM
Black02Z71's Avatar
Now what about a TSP 220 or TSP 224.
TSP 220R 1200-6200 rpm
TSP 224R 1400-6300 rpm
I know with stock heads the extra lift (.581" vs .563") won't be much of a benefit, but these cams should have less duration seat to seat.
More low end torque? Too hard on valve springs?
Old Dec 4, 2006 | 09:04 PM
TouchOfEvil04's Avatar
<-----Has the TR220-112LSA. Stock..or basically stock tune and 2600stall 13.5@100mph so far.
Old Dec 5, 2006 | 09:21 PM
99Silver6.0's Avatar
224 or bigger!!!!!!!!!!!!
Old Dec 5, 2006 | 10:48 PM
TXsilverado's Avatar
224 on a 114 is about as big as you can go and pass emmissions...that is if they do the sniffer. otherwise i would say the comp 226/226 112 on xer lobes
Old Dec 5, 2006 | 11:41 PM
dirt track racer 81's Avatar
here ya go 268/276@.50 on a 110 ls1http://video.ls1tech.com/category/Ca...d35da468f9.htm thats sounds wicked
if you can something 224 or bigger..my cam is sig runs just fine..pulls good to 6800 and im going bigger
Old Dec 5, 2006 | 11:46 PM
You got a dyno graph to prove that 6800rpm pull?????
