LQ4/9 + L92 heads & manifold = ???
Old Sep 21, 2006 | 10:46 PM
TurboGibbs's Avatar
Pretty much all the info you need is here. L92 Info
I'm sure the truck intake would be easy to be had. I've actually had someone from tech to pm me about buying theirs that they got on a crate engine L92. I just never considered it since it isn't what I want.
Old Sep 22, 2006 | 03:54 AM
blacksheep's Avatar
Originally Posted by 2004SSS
does anyone know if the truck intake for the 6.2 is available? does anyone know if the heads can be bought assembled from gm? part #?
a link to the sticky would be good too.
The truck intake is available, I have one sitting right here in my shop. I'm not sure if the heads are available assembled.
Old Sep 22, 2006 | 04:43 AM
TurboGibbs's Avatar
Here is some more info copied from the L92 info sticky.
At the moment I don't believe the heads are availiable. All production pieces now are going torward the assembly line. That was a month ago anyhow.
Old Sep 22, 2006 | 08:02 AM
04Denali's Avatar
TurboGibbs, in regards to the heads, do the exhaust ports/bolt pattern/position look same as our 6.0L ones? Have you tried to bolt up our exhaust manifold?
I read on lstech about all the guys waiting for the L76 intake. I know it's an Aussie car intake and that's why all the lstech crew want it for their cars. But as we have trucks, we would be able to use the L92 Esky intake, right?
I sifted through all the pages on lstech and realised the potential of the heads/intake but was really hoping to find someone who has got it installed.....
Please keep the info coming.....
Old Sep 22, 2006 | 08:54 AM
TurboGibbs's Avatar
I put an exhaust gasket up to the head and everything matched perfectly. As far as if the ports are raised or not I do not know. I don't think they are but if any not much. They are at the machine shop right now getting guides and seats put in them otherwise I would go and check. I bought mine with no guides and seats because it was the only way I could get them at the time and I needed them now. It would be cheaper to buy them with seats and guides or complete by far.
Old Sep 24, 2006 | 03:19 AM
04Denali's Avatar
Did you get your manifold complete with TB, fuel rails, injectors, etc? Would you know the Part Number for it? Do you plan on using it on a 6.0/408 and if so, does it look like there will be many mods getting it to work? Is the fuel rail set up for a return/returnless system? What about the TB wiring? Any other problems you can see? Any chance of some pics so I can try to compare it to our 6.0 intake?
Sorry for the multitude of direct questions..................I'm just keen to find out if it is a cost effective/realistic goal to get this stuff direct from GM and get it to work......
Old Sep 24, 2006 | 09:56 AM
TurboGibbs's Avatar
Once again, there is a pic in the LS1tech, L92 info sticky. It appears to be a returnless fuel rail.
Linky for the lazy
Old Sep 24, 2006 | 01:49 PM
02RedHawk's Avatar
Originally Posted by Richard@WCCH
We're in the beginning stages of working up a CNC port program for these heads and I can tell you that even straight out of the box they flow a bunch on the intake side. The exhaust leaves a bit to be desired.
These new heads have pretty large (volume) intake runners (260cc ) and may cause a loss of low end torque in 6.0l truck engines that use longer duration cams such as 224+º. These heads are ideal for engines in smaller lighter car type applications which is why they're so popular with the car crowd already. That being said, they can make for a nice N/A stroker 402 setup or a std. 6.0l with a power adder.
I'm not exactly sure why GM chose to install these heads on a truck first, but they did. Evidently they've figured out how to time the valve events to maintain low end grunt and driveability. The high intake flow handles the mid range and top end torque.
Lastly, always remember to try and choose a smaller duration cam when installing these heads and intake in a truck application. My best guess would be to down size the cam by 8-10º duration.
We should have a bit more info about these head swaps on 6.0l engines in the next couple of months.
Richard
Well said, Richard.
I believe there are going to be quite a few disappointed folks after installing the L92 setup, mainly because they don't realize (or understand) how HUGE the intake runners are on these heads....and how that's going to significantly affect the engine's power/tq output.
Old Sep 24, 2006 | 06:55 PM
litreddevil's Avatar
Banned
i will be doing this set up in january cnc is porting the heads and intake for me
Old Sep 24, 2006 | 08:17 PM
icedenali's Avatar
Are you going to use LQ4 block?
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
subeone
Aug 19, 2015 07:44 AM
USMCvet0311
Jul 29, 2015 01:28 PM
