Lq4?
Old Sep 8, 2008 | 03:25 PM
2ktransam's Avatar
How much power can I expect out of my setup?
LQ4 coming soon
STS MPT70
Z06 cam
10-11 psi
Old Sep 8, 2008 | 04:13 PM
nonnieselman's Avatar
LQ4 coming soon
STS MPT70
Z06 cam
10-11 psi
Your 60E is just goin to love you....
Ive heard of non intercooled WHipples putting down 500 to the wheels on 8PSI... Thats all i know of for sure.
Old Sep 8, 2008 | 06:45 PM
2ktransam's Avatar
Perfomabuilt claims there level 3 60E will handle 700hp/700tq. I guess I am going to test that.
Old Sep 8, 2008 | 07:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by thunder550
The only ones that aren't are the 99-00 with the longer crank snout on the back. All others will drop right in. The guy you talked to doesn't know what he's talking about.
Originally Posted by zippy
The 03-07' should work. There are some differences in the internals so they don't show them as being interchangable, but they are.
the 03-05 will work.. just put all your stuff on it and drop it in..
YES YES and Yes what they said. Somtimes people just don't know, esp ones at dealers and part stores still act like it.. hmmmm
John
Old Sep 8, 2008 | 09:44 PM
zippy's Avatar
If you get it all dialed in right you should hit 550RWHP fairly easily.
Old Mar 11, 2009 | 10:21 PM
luis897958's Avatar
Thanks guys. I found an 03 for $1,000 delivered with 57k miles, is that a good deal?
Wherer did you found it at? any website? I need one for a 2000 silverado....
Old Mar 13, 2009 | 04:03 PM
1FastBrick's Avatar
Custm2500's Rude Friend
What years of the LQ4 are a direct replacement on my 2001 Chevrolet Silverado? I only ask because a used parts dealer told me that the 03-05 LQ4 would not work in my truck and would not sell me an engine.
FWIW.... I believe the reason the Used parts dealer said no on the interchange is because of the change of exterior compentens like the electronic throtle body and the return less fuel system that will not work in the early truck wich had a cable throtlle body and had a return style fuel system... Some of the intake manifolds had an Egr tube passage near the throttlebody and the later ones don't have a provession for that...
Its not really a big deal as long as your original Parts are useable They bolt up exactally the same... all you would really need to be concerned with is the basic long block and that it's in good shape as they described...
Hope that helps clear it up for you and others that might be looking to do the same. Yes $1000 is a good deal esspecialy since it includes delivery.... On a side note Always inspect it before taking possesion of it. Make sure it rotates freely 360 degress.
At work, I have had 3 used enginges and 1 transmission (Ironically None were Chevys) that gave me a problem... One, we bought as a basic long block that was was supposed to be an 80k pull out. We only needed the bottom half but It ended up haveing a broken timming belt and the valves kissed the pistons... The other one had a cracked Oil pan that was not viseable. I installed the engine, went to fill it up and about a quart of fluid leaked all over the floor as I started filling it up. it was a 4x4 and it was a pain in the *** to swap the pan out. another one had dual chains and one of the chains let go inside. It would only turn about 1/2 over till it became bound up by the broken chain... Oh and I got 1 used transmission that seemed ok untill I put it in and started it up, The pump was going out and the clutches were burned up... That one was real iritating because they said they were gonna get us another one. After they screwed around for nearly a week I had to drive out there, drop it off in person and get our old core back and a cash refund. Good thing I get paid by the hour...
Old Mar 13, 2009 | 09:45 PM
colekill's Avatar
KickinAssAndTakinNames
so an 04 lq4 wouldnt bolt up in my 99? what would i have to do to make it work?
Old Mar 13, 2009 | 10:01 PM
1FastBrick's Avatar
Thats not what He said. The Lq4 in 99 and 00 had a Longer crank rear snout to work with the 4L80E. In 01 they started using a standard length rear snout and adding a spacer between the crank and fly wheel. In order to use an 04 LQ4 in a 99 with a 4l60E you have to remove the spacer and use the fly wheel, the shorter bolts, and starter from your existing 4.8/5.3 . You will also have to swap out your intake mainfold wich has a cable driven throttle body Vs. the 04 with it's electronically activated servo throttle body. Your 99 will also most likely have an EGR set up off the Exahust manifold and the 04 will probally not have provessions for that.
Old Mar 13, 2009 | 10:54 PM
colekill's Avatar
thanks for the clarification. i'll keep that in mind for when my 5.3 170k blows up.
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
