Loud squeal
Old Sep 1, 2009 | 07:14 PM
truckmann's Avatar
Default Loud squeal
Coming from my truck after it's warmed up. It was running fine until I put on a TBSS intake. Can't figure how switching intakes would have caused this. I'm afraid it might be a main bearing as it is loudest under the truck. At first I though it might be the alternator but I have verified it isn't anything driven by the main belt.
Old Sep 1, 2009 | 07:17 PM
GMCtrk's Avatar
Are you sure there isn't an air leak? You said you had RPMs not going down on decel....indicating an air leak
Old Sep 1, 2009 | 07:22 PM
truckmann's Avatar
No I'm not 100% sure of that. Guess I can run and get some new intake gaskets although the RPM on decel problem doesn't seem to be a problem any longer. With the squealing as loud as it would be hard to believe it's an air leak but anythings possible. I know some new gaskets are sure cheaper than a new engine.
Old Sep 1, 2009 | 07:24 PM
GMCtrk's Avatar
You just replaced the manifold. It's highly unlikely that something catastrophic happened right when you made that change. It's something related to the manifold.
Old Sep 1, 2009 | 07:26 PM
truckmann's Avatar
I agree with you there I just get worried about my stuff falling apart to easily with my bad luck.
So guess I'm off to get some intake gaskets now.
Old Sep 1, 2009 | 10:39 PM
truckmann's Avatar
Well I think I figured it out and it wasn't the intake gaskets although it was probably good I replaced them anyway. Seems the port I chose to use for the pcv/crankcase vent in the passenger side valve cover is too much vacuum for it. I unhooked it and went for a drive and no more squeal (at least not yet). Now I need to figure out where to hook that thing up.
Old Sep 1, 2009 | 10:43 PM
GMCtrk's Avatar
You could just put a breather on it and then cap off the PCV line.
Old Sep 1, 2009 | 11:04 PM
truckmann's Avatar
I'll sure have to figure something out. The TBSS intake doesn't have the same port for that vent like the truck intake so I tried using a T off of the port on the top. Apparently that was a bad Idea.
Old Sep 2, 2009 | 11:15 AM
budhayes3's Avatar
PT's Slowest Truck
There was a good thread around here not too long ago about the benefits of a properly working PCV system, I can't understand why anyone would want to eliminate it.
The hose going to the passenger side is just a vent, and the driver's side that has the PCV requires vacuum. I believe that the newer (than mine at least) trucks have a fitting for the vent on the throttle body. You could always drill a hole in the air intake tube and fab some sort of plastic fitting to plastic weld/hot glue/whatever, and run the vent hose to there, or get a newer throttle body, depending on what's available and will work on your truck...
Old Sep 2, 2009 | 11:41 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yep.
That squeal is from the PCV system I'm willing to bet. I had the same thing on my truck when I install both Krank Vents into my PCV system. When I removed the one on the front, it was back to fine.
