lost a lifter, cam and #7 cylinder.
Old Jan 16, 2010 | 07:08 PM
black04silverado's Avatar
Default lost a lifter, cam and #7 cylinder.
in my 5.3 i pulled it to do a 6.0 swap and did a compression check. 55-60 in all cylinders but 7 it only had 28 ish. also pulled the cam to reuse it in the 6.0 but it was toast also the lifter is all chewed up. so a new 6.0 and a custom grind cam from texas speed. so new number coming soon.
a few pics of the cam.
Old Jan 16, 2010 | 07:11 PM
SLOXCAB's Avatar
damn that....how long ago do you think that lobe died?
Old Jan 16, 2010 | 07:13 PM
dirt track racer 81's Avatar
your cam doesnt look so well.. got the 5.3 tore apart yet?
Old Jan 16, 2010 | 07:17 PM
jhe2003's Avatar
What brand cam? Re-grind?
Old Jan 16, 2010 | 08:27 PM
the cam only has about 10k miles on it im guessing its been slowly tearing up for the past 6 months the lifter looks about the same
yeah i sent a order in for a new cam it should be here tuesday or so... i tore the 5.3 most of the way down. everything looks good but the cam lifter and the rings for #7
its a comp cam and i got it brand new.
Old Jan 16, 2010 | 08:50 PM
MikeGyver's Avatar
Get new lifter trays. I would change mine every other oil change if it was easy.
Or when you say a new 6.0, do you mean brand new?
Old Jan 16, 2010 | 08:54 PM
MikeGyver's Avatar
55-60, and 28 what? Is that kPa?
Old Jan 16, 2010 | 11:50 PM
Pontiac Derek's Avatar
Over on LS1tech there is a Miriad of threads on guys losing LS7 and Caddy Lifters on Aftermarket aggressive cams, i'm upgrading to the more expensive Morels but its good insurance as cams are not cheap!
superchomper2003
Aug 26, 2015 09:39 AM
Jake75
Aug 5, 2015 01:26 PM
lxcoupe
Jul 30, 2015 02:42 PM
Suburban2500
Jul 19, 2015 04:50 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
