Looking for a how to for Head Swap????
Old May 25, 2007 | 08:13 PM
TouchOfEvil04's Avatar
The stock gaskets won't limit any airflow now that they will be worked over?
I need the ARP bolt and studs or just the bolts?
Old May 25, 2007 | 09:17 PM
BlownChevy's Avatar
blownerator
25 Year Member
There are people running 14#s of boost on stock gaskets and ARP studs you will be fine.
Old May 25, 2007 | 09:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
No because the stock 6.0 gaskets are 4.04 bore IIRC, they will do nothing to hurt performance and if you have a hook up at a dealer arent oto bad in price ocmpared to cometics. Bolts will be fine I dont htink you can install studs withouth removing the motor. Bolts will be fine.
Old May 26, 2007 | 12:05 PM
thunder550's Avatar
High on diesel fumes
FWIW my 408 is getting stock gaskets this time around.
You can do studs with the motor in the truck.
Old May 26, 2007 | 03:23 PM
ZZebes's Avatar
How?? teach me Obi-won
Old May 26, 2007 | 04:38 PM
thunder550's Avatar
When I pulled my heads I removed the studs first. Passenger side I set the new head in place, then installed the studs, then the nuts.
Driver's side I installed the studs first and was able to fit the head over top of them. I didn't try the passenger side like that, not sure if it would have worked or not.
Old May 27, 2007 | 03:23 PM
Cool, i think i'ma grab the sstock gaskets from Thunder racing since i live close by and there like 30something bucks.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
