looking to do a cam swap need advice
ive got a 2000 chevy ext cab 5.3 4wd, i was wanting more power and i need to take the engine apart anyhow to check things as it has 194k miles the only modifications it has is a k&n cold air intake, Gforce chip, and a higher flow exhaust
how much money you wanna blow on it?
Cam helps some but need headers to get all the power out of it.
Then a Stall so you can get to the power quicker
How big of tires? Gear ratios?
gonna have to get a good posi unit too
Those are pretty meaty tires for the 3.73's you have. Without a converter it will be a bit of a dog...
Also... the cam swap alone will cost you 7-800. Along with the cam you will need to swap the valve springs and the pushrods, then all the gaskets and fluids to accomplish it.
For a lifted truck I usually tell them to go straight for boost...
Me like boost!! but its not for the faint of wallet per say..
gonna need a good trans and a good posi unit, then a good fuel system and all the lil things. but theres nothing like it for power
ARC
57
Feb 21, 2022 10:54 AM
Nimoryan
Jul 5, 2015 03:50 PM
