longer crank pulley bolt?
Old Mar 6, 2006 | 09:39 PM
Default longer crank pulley bolt?
Hey guys, I have been posting on here for about a week trying to find all the info I can on doing a cam swap in an 05 5.3 chevy. Three quick questions. What is the deal with a longer than stock crank pulley bolt? Where do I go find it? What do I ask for when I get there (dimensions)? Thanks a lot. I hope to get this project underway on Saturday and want to have all my ducks in a row.
Old Mar 6, 2006 | 09:59 PM
phasemaster1's Avatar
I didnt use the longer bolt i used propane torch and it worked. I heated the pulley throat and slapped it on slid in good amount.
Old Mar 6, 2006 | 10:11 PM
TurboGibbs's Avatar
I always use the propane torch method. Heat it for about 30 seconds, put a little grease on there to help it out and it should slide all the way on.
Old Mar 6, 2006 | 10:13 PM
Thank you mjhoward worked like a charm.
Old Mar 7, 2006 | 07:31 AM
I am just imagining or have I heard that the balncer bolt is for one time use only? Oh and by the way, I am the one who bought the cam from gmcwaldoch that came out of mjhowards pickup I believe. The cam is 216/221 w/ 558 lift. Is this cam ok with the ls6 springs provided and is it going to be ok with stock tune and converter until I can do better? Thanks a lot guys I wouldnt be able to do many things without the help I get on this and LS1tech forums.
Old Mar 7, 2006 | 07:35 AM
TurboGibbs's Avatar
Yes, it is a torque to yield bolt. You torque to 37ft lbs then rotate 140*. It stretches. You can get a new one from the dealer for less than $5. Some people have much success with puting some locktite on it and tqing it to 250lbs or so. The balancer will work its way off if you don't do one of the above methods. I just by a new bolt for as cheap as they are. getting the bolt to stretch can be a pain in the **** and usually takes 2 people.
chevysten
Aug 13, 2015 07:36 PM
vipergtrdj
Aug 6, 2015 10:19 PM
bigsapper
Jul 28, 2015 12:56 AM
blownss27
Jul 20, 2015 08:59 AM
GreyChevy
Jul 7, 2015 08:57 PM
