Which Lifters are you using
Old Mar 18, 2014 | 08:10 AM
RS/SS 4.8's Avatar
10 Second Truck Club
Default Which Lifters are you using
Ive seen plenty of builds on here making crazy amounts of HP and i was wondering what kind of lifters you are using. Im building a 370 that was gonna see boost but its going to run N/A for a while. The cam is a 222/601/115 with BTR double springs on 317 heads. I was thinking the BTR SLR lifters or the Morel street link bar ones. Which ones have you used that stood the abuse of your leadfoot. BTW this will be a daily driver seeing alot of highway miles so i dont know if that makes a difference.
Thanks
Franm
Old Mar 18, 2014 | 01:28 PM
jmgak47's Avatar
I run Morel in my 454 LSX and LS7 in my LQ9 daily.
If you want to spend the coin go with Morel.
Old Mar 18, 2014 | 03:42 PM
69Camaro427's Avatar
Ls7 will work, never had an issue with any. A buddy has a 408 pro charged on 12-15lbs running ls7 for the past 20k and no issues
Old Mar 18, 2014 | 04:10 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
I'm running the BTR SLR ones so far there great id highly recommend them
Old Mar 18, 2014 | 09:21 PM
GREENSIERRA's Avatar
I am running LS7 in my L33 but ordered Brian Tooley without the link bar for my LQ4
Old Mar 18, 2014 | 10:36 PM
black00chev's Avatar
Slowest turbo build ever!
Im running LS7s and based on my experience Ill never use them again. Maybe the Cadillac racing lifters, otherwise I will most likely go with the Brian Tooley SLR lifters next time around. Or if im pushing some serious(600+) power, than the morel link bar lifters.
Old Mar 18, 2014 | 11:28 PM
oakley6575's Avatar
I'm running the ls7's but will order tooley lifters next.
Old Mar 18, 2014 | 11:48 PM
I don't know about anyone else, but my LS7 lifters seem to be fairly noisy around the 1500-2000rpm range. Was using 5w-30 and switched to 10w-30 and they quieted down some but still seem louder than they should be.
Old Mar 19, 2014 | 10:55 AM
tim wellington's Avatar
Default lifters
are these morel and brian tooley lifters the same height as factory lifters . i doing a rebuild and i dont want to have get longer push rods($) running 7.400 now. street engine
Old Mar 19, 2014 | 03:46 PM
jmgak47's Avatar
What length pushrods are you running?
