Lifter Tray Mod
Old Dec 4, 2009 | 04:21 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Default Lifter Tray Mod
Has anyone done this to their motors?
Old Dec 4, 2009 | 05:06 PM
Rick_Vor's Avatar
I've wondered the same thing after reading that book a few times. This a post about it on LS1Tech. As long as you don't crack one while drilling, it sounds like it can't hurt.
https://ls1tech.com/forums/generatio...-tray-mod.html
Rick
Old Dec 4, 2009 | 05:08 PM
hirdlej's Avatar
I wouldn't. Drilling into plastic is scary. I'd be afraid to put a stress fracture into the plastic and potentially have the tray crack. Thus causing a lifter to spin. Leave well enough alone. People talk but have you ever really seen a LSx motor where the crank bearings starved from the lifters holding too much oil? Only on a autox setup MAYBE.
Old Dec 4, 2009 | 05:09 PM
hirdlej's Avatar
Oooh I see joe mullet in the pic again!
Old Dec 4, 2009 | 05:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
For once I agree with you
Old Dec 4, 2009 | 08:00 PM
closet red neck's Avatar
I don't agree......I did this to the 5.3 set-up and can be done very easily. When I tore down the motor, the lifter trays where fine with 7000rpm shifts. It couldn't hurt. Just use new bits and go in increments until you achieve 1/2 hole.
James
Old Dec 4, 2009 | 08:10 PM
ForcedTQ's Avatar
Thumbs up
James
If you do perform this mod, I'd do as posted above. Use plastic trays that are new and have not been subjected to heat and oils that will make them brittle. You stand less of a chance to impart damage via a stress fracture that you cannot see with your naked eye.
Old Dec 6, 2009 | 12:10 PM
I did it in my old 5.3L set-up and I am doing it on my new project!!!!!!!!!!!!! all you nees is a step up unibit..............that will work just perfect
Old Dec 10, 2009 | 10:48 AM
Hawk179's Avatar
This is correct. I have done this mod on a few motors and there is no way of telling if you are doing anymore good than harm. So I leave them alone now.
R
JordanH
Nov 6, 2015 07:42 PM
gmcyukon
Oct 5, 2015 06:20 AM
gmcyukon
Oct 3, 2015 11:03 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
