The lifter preload game
Old Jul 18, 2015 | 04:01 PM
GM1697's Avatar
Default The lifter preload game
Okay so my current pushrods (7.4) leave me at a .068 preload, according to my math and the adjustable pushrod measuring tool.
Should I swap these out for 7.425 to get extra preload and come to a .093?
I already have posted the 7.4's in the classifieds.. but I figure I should ask before pulling them out.
Also I have my rockers torqued to 25 ft lbs, instead of the 22 ft lbs that is spec, because my torque wrench doesn't go that low, is this terrible?
Old Jul 18, 2015 | 05:37 PM
GMCtrk's Avatar
.068 is perfect, leave it be.
Also, you're playing a very dangerous game using that torque wrench on the rockers. Torque wrench is inaccurate at it's extremes of range and you might be putting more torque to it than 25. Those rocker bolts can strip or break pretty easily.
Old Jul 18, 2015 | 06:50 PM
GM1697's Avatar
in reality the wrench goes as low as 20 but I was considering that it must be inconsistent so I turned it to 25 figuring by then it should be atleast a exact measurement. in retrospect this may have been a poor decision.
Old Jul 18, 2015 | 10:15 PM
GM1697's Avatar
somebody tell me it's fine so I don't tear off the valve covers tomorrow and redo it.
Old Jul 18, 2015 | 10:22 PM
GMCtrk's Avatar
If it was me, I would loosen them up and torque to spec.
Old Jul 18, 2015 | 10:53 PM
BlackGMC's Avatar
Resident Retard
get a smaller tq wrench. I have 2, a small one for 20-25lbs and a big one. The small one is a 3/8 drive, the big one is a 1/2 drive...
Old Jul 18, 2015 | 11:14 PM
Atomic's Avatar
I have a gauge for that
Am I the only one that uses the German torque wrench on the rockers and never had a problem...
Old Jul 19, 2015 | 04:00 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Das-Good-N-Tight ???
I think I have about 7 torque wrenches for various torque ranges. If there is ever a question on torque value, I send them out for a rebuild.
FWI, Always back the torque value off when you're finished using a torque wrench. By turning it up to the MAX value, you are collapsing the spring inside. Leaving it like that for long periods of time will weaken the spring and throw off the torque values.
9 out of 10 of my customers wind them all the way up and can't seem to grasp this concept. When I come in to inspect their equipment, I usually have to explain it over again. Yet they never listen or follow my recommendation.
Old Jul 19, 2015 | 06:54 AM
GM1697's Avatar
I am religious about back off the spring after every use. So I hope my wrenches are close to correctly calibrated.
So is the consensus that I should redo it? Or should I just leave them?
Old Jul 19, 2015 | 04:09 PM
GM1697's Avatar
I went back and redid them. 22 ft lbs with loc tite.
And I'm just gonna leave those pushrods in.
