Lazer Cams?
Old Dec 23, 2008 | 12:14 PM
00Silv4.8's Avatar
Default Lazer Cams?
come to find out "LC" on a cam is not Lunati, its Lazer Cams???
anyone heard of them? trying to do research and all but cant find a dam thing. Found "ron's pontiac forum"? and it had a list of Lazer's cams. I found mine but specs are wrong from what I was told. Smaller LSA and less lift? Other than that it says they're number is disconnected and I cant find a website ANYWHERE. Any insight? I really want to know that I know the specs and RPM range.
Old Dec 23, 2008 | 07:09 PM
dirt track racer 81's Avatar
last i knew lazer was makin ford dirt track cams
Old Dec 23, 2008 | 09:11 PM
lsx10's Avatar
where did you get thins thing from? I've heard of getting the cams spec'ed, but I can't give you much info on it. if you have a good caliper then you will be able to find out the lift. if you don't have one then a friend or your machine shop will.
1.find the smallest part and this is your base circle
2.now find the largest part, write this down
3.subtract 1 from 2 and this is your lobe lift.
4.multiply 3 by your rocker lift ratio ie. 1.7 1.8 whatever you have(stock is 1.7) this is your valve lift.
this is just a basic thing but it will at least narrow your search down when you can get ahold of the cam company.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
