L92 reluctor wheel
Old Apr 7, 2010 | 06:03 PM
Iraq Sucks's Avatar
Default L92 reluctor wheel
What is it and do I need a 24x or 58x for a 416 stroker build?
Old Apr 7, 2010 | 06:15 PM
budhayes3's Avatar
PT's Slowest Truck
If it's for your 08 then you'll want a 58 tooth reluctor wheel It's a wheel on the crank shaft that the crank sensor gets it's signal from...the crank sensor has a magnet in it and it's signal fluctuates as the metal teeth of the wheel pass the magnet.
Old Apr 7, 2010 | 09:33 PM
Iraq Sucks's Avatar
do I need to convert anything on the vehicle if the 58x comes on an assembled shortblock?
Old Apr 7, 2010 | 11:28 PM
Ferocity02's Avatar
No, the PCM and crank position sensor will already be set up for 58X.
Old Apr 8, 2010 | 01:07 PM
Iraq Sucks's Avatar
so the more teeth, the more constant the signal is I assume?
Old Apr 8, 2010 | 01:23 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
The 24 reluctors are for NBS trucks 99-06 GM switched to 58 wheel on the NNBS 08-10 trucks.
Old Apr 8, 2010 | 02:26 PM
Ferocity02's Avatar
I don't think more constant is the right term, but I think more teeth gives the PCM a better idea of where the crank is. How this might translate to improved performance, better fuel economy, changed whatever, I don't know.
Old Apr 9, 2010 | 02:00 PM
Callies Performance's Avatar
FormerVendor
And the best Part, GM is once again going to change the reluctor! The new one will still be 58 teeth, something about positioning. -Adam @ Callies
Old Apr 9, 2010 | 06:32 PM
Iraq Sucks's Avatar
Just the answer I was looking for, thanks.
Old Apr 9, 2010 | 07:01 PM
EXECUTIONER6.0's Avatar
dame i learn alot in this fourm
