l92 heads ? what intake?
Old May 2, 2007 | 03:31 AM
RickLowpez's Avatar
Default l92 heads ? what intake?
my rcsb o6 has a fully bolton lq9 with supposibly ported 317 heads.???????? will the new l92 heads and intake help? what intake the car or the truck one? what gains should i be getting? i was told 50 to the wheels
Old May 2, 2007 | 09:00 AM
Richard@WCCH's Avatar
FormerVendor
There's a number of car guys on the Tech side that are making over 500rwhp with relatively small cams (mid 230's) with L92 heads. The car style intake (L76) will make more upper rpm power than the L92 intake. You will have some fab work to do to install this on your truck. It's not just a bolton upgrade. You will have to do some work to the fuel rails, wiring etc. Also, it would help if you have some 1 3/4" long tubes or better yet 1 7/8" pipes.
Richard
Old May 2, 2007 | 09:02 AM
yurs78's Avatar
Do an L92/L76 search, there are a lot of good discussions out there on it. Search button is in the top box just to the right of center. Good luck.
Old May 2, 2007 | 09:48 AM
Quik's Avatar
5 year bitches!
for the l92s run the l76 intake. i have that setup on my 408...as for numbers none yet
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Jul 29, 2015 01:28 PM
NuckenFuts
Jul 9, 2015 08:45 AM
