L92 Fuel Rail problem ?????
Old Feb 28, 2011 | 11:30 AM
70ls1chevelle's Avatar
Default L92 Fuel Rail problem ?????
Going from 5.3 truck intake setup to L92 truck intake setup.What do i need to do with the fuelrail ? 1999 fuelrail has regulator and feed & return lines.L92 fuelrail has no regulator and feed line only ? Do i need to do anything with the valley cover or bolts ? Any help Thanks
Old Mar 3, 2011 | 10:41 AM
Anyhelp ?????????
Old Mar 8, 2011 | 03:29 PM
Any help again ?????
Old Mar 8, 2011 | 03:55 PM
Robert91RS's Avatar
Unless your 6.2 has AFM you shouldn't need to do anything with the valley cover. As far as I know there are not any factory return style fuel rails that are compatible with the L92 intake so you may need to purchase an aftermarket set, but IF somebody can confirm that they would bolt down without the crossover tube you might be able to modify a pair. Alternatively you could mount an adjustable fuel pressure regulator(w/return) in the engine compartment and then just run one braided stainless line to the factory L92 rails.
Old Mar 8, 2011 | 04:15 PM
kwk174's Avatar
I got a 99 corvette fuel filter that has the regulator in it. When i did my l92 swap i moved the lines more towards the passenger side and connected the fuel filter directly to the fuel rail with the inlet and return line connected to the filter.
Old Mar 9, 2011 | 08:12 AM
zippy's Avatar
This is pretty much the most cost effective way to do it.
Old Mar 12, 2011 | 05:55 AM
iamkeniff's Avatar
you can do that or clear up some space and run about 3-4' of SS fuel line with the vette filter on the frame rail vs in the engine bay. i think thatd be a pita to change when it comes time.
kwk174 care to post some pics of it? it may be less cluttered than im thinking.
OHsixLS3
Dec 27, 2016 09:30 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Deceptarado
Jul 8, 2015 05:24 PM
