Internal engine bolts?
Old Mar 16, 2010 | 12:25 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Internal engine bolts?
I know head bolts are TTY so they cannot be reused, but what about other bolts? Such as rod bolts, main bolts, cam plate bolts, etc, are they torqued to yeild or are they reusable?
Old Mar 16, 2010 | 12:27 PM
CODE4LS1's Avatar
Mains are TTY and should be thrown away once loosened.
Old Mar 16, 2010 | 12:54 PM
thunder550's Avatar
High on diesel fumes
Rod bolts, main bolts, and head bolts should not be reused. The rest are ok IIRC.
Old Mar 16, 2010 | 01:00 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Correct. The crank snout/pulley bolt is also TTY.
Old Mar 16, 2010 | 01:56 PM
thunder550's Avatar
Yep, forgot about that one.
Old Mar 16, 2010 | 06:24 PM
dirt track racer 81's Avatar
My crank bolt has been reused over ten times..no problems..
Old Mar 16, 2010 | 06:38 PM
thunder550's Avatar
I tried to reuse one once and stripped about half the threads out of the crank snout.
Old Mar 16, 2010 | 06:47 PM
did you try to pull the balancer on the crank on with it? Ive always used the tool to put the balancer on and then screw in the bolt and hit it with an air gun.. never had any problem. The one time I did try to pull the pulley on with the bolt i stripped the threads
Old Mar 16, 2010 | 08:13 PM
danger_ranger83's Avatar
heat it and slide it on ... i think its a waste to buy a new balancer bolt...how may people actually torques it down to spec? TIGHT is good enough
Old Mar 16, 2010 | 09:08 PM
TURBHOE's Avatar
it better be damn tight. i personally seen one that was not tight enough. the bolt worked out then the pulley started to wobble. it basically ruined the crank snout. we had to key it in two places to make it work correctly again. how tight he had it i don't know. just putting it out there. i crank mine to 250ftlb as speced to seat the pulley.
