intake manifold sound?
Old Mar 10, 2008 | 03:30 PM
BlaCK-on-BlacK's Avatar
Question intake manifold sound?
i have a sound near the intake manifold or inside it
its sounds like '' tic '' tic '' tic '' when i drive and the gear on 4th or 5th its going littel bit louder ?! did anyone have any idea???
Old Mar 10, 2008 | 05:11 PM
06sierra5.3's Avatar
lifters? could be the injectors cycling.
Old Mar 11, 2008 | 02:58 PM
hmmmm i don't know :S
Old Mar 11, 2008 | 02:59 PM
so the injectors could be damaged ?
Old Mar 11, 2008 | 03:04 PM
also i have another problem with the electricity i have changed the plugs wires and i put msd red wires and new racing plugs .. new car battery ? and the electricity gauge still down the half and nearly to quarter ? i dont know what to do and when its go down all the lights in the car go down and up agine when i rise up my rpm?
Old Mar 11, 2008 | 04:02 PM
no, not damaged. i was a jaguar tech, their lifters were freakin noisy, especially with the engine covers off. it depends. what injectors are you running. you couldve just got a noisy batch, or you could have one that is failing.
easiest way to find the noise is to get a doctors stethescope and put it on the injectors, manifold etc. you'll know when you find it, it will be loud.
Old Mar 11, 2008 | 04:05 PM
have you had any body work done recently? or had any parts off? could be a bad connection. you'd be surprised how little it takes to create a bad connection. check all the contacts and connectors/eyelets form the starter altenator battery etc. check ground straps. even if they are dirty they could cause an annoying problem. i've found some trippy stuff on cars.
disconnect and reconnect both battery terminals, make sure they are clean and make solid contact. if the problem is still there after that, consider taking it to the dealership to have it diagnosed with their equipment.
Old Mar 11, 2008 | 04:42 PM
another thing i was thinking about. if its that loud that its bothering you while youre driving, it very well could be a valve getting ready to let go. the old 5.2 dodge heads were notorious for slamming the valves into the seats, not allowing proper sealing of the combustion chamber. it can happen to any head.
if you have the equipment, do a cylinder leakdown test. about 100psi into each plug hole and let it sit. if the valve isnt sealing, youl see the psi drop consitently.
where are you located?
Old Mar 11, 2008 | 05:37 PM
hmmm thanks for helping
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
