Installing a PLX boost gauge....
Old Nov 6, 2008 | 10:59 PM
r1les's Avatar
Default Installing a PLX boost gauge....
I just got the PLX DM100 in the mail and I got the afr and boost set up.But the directions are a little fuzzy when it comes to hooking up "analog" wires together to teh sensor modules etc etc.Some people are great at confusing directions....Im not one of those guys trust me If you check out the directions I do have RX and TX wires hooked up and the others "daisy chained" together.But the analog wireing and how to power the 3 together is confusing?There are 2 sensor mudules (afr/vac-boost) and the main display module.Help!
Old Nov 6, 2008 | 11:24 PM
Derek @ EDO's Avatar
FormerVendor
Starting with the DM-100 Display module, plug in the male connector to (RX) under the Sensor side, the other end will connect to your first SM or "sensor module"
Connect to TX on the sensor module. Be sure to remove the termination jumper from the sensor module because you will be adding another one to the chain.
Coming off the sensor module you just hooked up connect to the (RX) jack with another male to male jumper wire.
Since this is the last sensor module in the chain do not remove the termination jumper.
Here are the install instructions with a few diagrams.
http://www.plxdevices.com/Installati...Guide_F2.0.pdf
If you are still having problems feel free to shoot me a PM or call PLX tech support @ (650) 793-5834 They will gladly walk you step by step until you have everything sorted out.
Derek
Old Nov 7, 2008 | 06:53 PM
r1les's Avatar
Thanks.Yeah I just called someone from PLX and they were down at the SEMA show.But they did clarify any mis-understandings.I found out that you dont have to use any of the analog wires or plugs unless your hooking it into a computer or the computer.Verbal instructions are sometimes better interpreted than typed instructions
thunder550
Oct 8, 2015 04:53 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
slowlsx
Jul 13, 2015 04:18 AM
