Installing ARP rod bolts?
Old Oct 29, 2009 | 03:49 AM
1_fastsilverado's Avatar
Default Installing ARP rod bolts?
So I got them installed today and torqued down to 45 ft/lb. I did a little search on here and see people talking about loosening and tightening them for the proper stretch and also something about threaded sleeves. I didn't see anything on mine that looked like it was threaded. I also did the bolts one at a time just in case anybody throws that out there. Thanks!
Old Oct 29, 2009 | 11:15 AM
budhayes3's Avatar
PT's Slowest Truck
I believe that there are some sleeves in the rods that you must remove when installing the ARP's, but I'm not 100% sure. I've also read on Tech about the ARP's warping the rod cap, but that was a while ago, they may have changed the way they make the bolts as many have used them without problems. Personally, if I were to change my rod bolts I'd go with Katech as they are designed like the factory bolt, only stronger.
Old Oct 29, 2009 | 11:38 AM
I checked out the Katech site, and that's exactly how the ARP's look..haha they must have changed them due to katech's bolts being better. I don't know about the sleeve thing yet, when I put the bolts in last night they slide through the cap not problem and then screw right into the rod, no binding at all. I guess all I'm going to try is the 3 rule for stretching and see what happens haha.
Old Oct 29, 2009 | 12:04 PM
MPFD's Avatar
11 Second Truck Club
Not sure about the threaded sleaves? I don't believe the were really warping the caps, there was a wives tale out there for a little while that if you changed to ARP rod bolts you had to resize your rods cause people thought that they would be out of round. I believe that it was people just trying to change them in the car, and pulling caps and not paying close attention to the bearing location/position on reinstallation. I went through and loosened and tightened to the spec on the ARP website I believe it was like 3-4 times of torqueing and loosening of each bolt before final torque was set. I did it that way with no problems.
Old Oct 29, 2009 | 01:17 PM
SLO TRUCK's Avatar
both sets of stock rods had sleeves that i put arp's in. the rods caps, have the sleeves in them you just have to tap them out and then the new bolts slide right in.
Old Nov 1, 2009 | 12:40 AM
bohr898's Avatar
Restricted User
when i put my arp's in... when i removed the old bolts the sleeves came out with the bolts and werent able to be seperated from the stock bolts... or atleast very easily werent seperable
5.3Okasai
Mar 9, 2022 01:07 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
black6spdz
Jul 16, 2015 01:32 AM
NuckenFuts
Jul 9, 2015 08:45 AM
