I want to hear your input on studs/gaskets for a stock block turbo setup.
Old Mar 18, 2019 | 07:39 AM
smokeshow's Avatar
Mod with training wheels
That's not true. I took the 100K mile plus LQ4 in my turbo truck apart and there still fairly tight considering. The rings don't wear as much as most people think. If I recall the top ring was still .016. even after a light ball hone.
I bent 2 rods in the direction of the wrist pin which damaged the bottom side of the piston when it kissed the counter weight at the parting line. I decided since there is no sign of detonation and it appears to be running clean, I would just slap it back together with 2 replacement pistons and rods and re-use the rings and bearings in there respective holes.
Block had to come out for cam bearings any way so it got a light ball hone in all the holes as well
So much work when it was just fine when it left here
Old Mar 18, 2019 | 11:15 AM
1FastBrick's Avatar
Custm2500's Rude Friend
On 4PSI that barely made a difference...
Actually #2 and #4 cam bearings had the lube holes blocked. Was also starving the lifters.
It has new cam bearings, a new baby cam, new lifters, and some yellow springs now...
You could buy it back and let it sit at your place...
Old Mar 18, 2019 | 02:03 PM
smokeshow's Avatar
Bent rods sure do make a difference
Old Mar 19, 2019 | 07:12 PM
randeez's Avatar
lowers the compression, so you can run more boost
Old Mar 20, 2019 | 06:05 AM
1FastBrick's Avatar
Like Eazy E said; "I looked at my car and said Oh brother, I'll throw it in the gutter and go buy another..."
Rey has a new paper weight for his desk now
Old Mar 20, 2019 | 12:10 PM
Resolute_welding's Avatar
You guys are ridiculous. Since there's an audience, y'all change timing chains when you do a cam swap on a high mileage motor or let her eat?
Old Mar 20, 2019 | 12:38 PM
smokeshow's Avatar
Cheap to replace. Swap it.
Old Mar 20, 2019 | 01:16 PM
1FastBrick's Avatar
Some do , Some don't.
I did, and typically do replace it with a new one just for peace of mind.
The HD Chain through GM #12646386
or an IWIS one through vendors #3SR602PS
Old Mar 20, 2019 | 02:44 PM
That's easy enough! I didn't know they sold just the chain, so I'll definitely pick one up.
Old Mar 20, 2019 | 02:59 PM
Dragonmedic67's Avatar
Registered User
You're kidding right? A new chain on worn gears?
