I think I broke a patriot gold spring
Old 03-02-2010, 09:53 PM
Wearin' da big hat
00ChevyScott's Avatar
Hahaha I was thinking the same thing Atomic
Old 03-02-2010, 09:57 PM
GMCtrk's Avatar
if the valve is in the cylinder that would account for the 5 reading. lol.
Old 03-02-2010, 10:07 PM
dirt track racer 81's Avatar
geez man go pull the cover..
Old 03-02-2010, 10:09 PM
jophuss36's Avatar
You guys think it's possible to just get away with springs?
Old 03-02-2010, 10:19 PM
so u gna pull the cover??
You may have other problems.. With the Patriots being dual springs and say just the outside spring was broke I would think you would have more compression than that.. Could have a bad ring, piston or both springs are broke.. Go pull that cover..
Old 03-02-2010, 10:24 PM
jophuss36's Avatar
I work at 430 am Tom so I'm going to get that stripped bolt off and pull that cover tomorrow... I'm just going to say a little bedtime prayer that I get lucky
Old 03-03-2010, 07:09 AM
1dirtybird's Avatar
Saw two broken inner springs on set of Gold's last week. The cam was .650 ish lift though, so not too sure why they used them in the 1st place. Car had missfires on both cylinders broken springs. Lunati has a new set out that look pretty swell.
Old 03-03-2010, 08:24 AM
Tootall's Avatar
use a dremel to cut off the head.
Originally Posted by 2005 Silverado
Patriots are high maintenance, the are supposed to be checked every 10,000 miles for correct spring rates.
I've never heard of that. Is that anywhere in writing, is it just your rule of thumb, or something that you've been told?
I have a buddy that broke all 8 intake springs from using the stock spring seats vs the ones that have come in the kit.
Old 03-03-2010, 10:35 AM
chevyridinhigh22's Avatar
got that cover off yet?
Quick Reply: I think I broke a patriot gold spring
