I know that in 05 the rods on the lq motors changed??
Old Aug 17, 2009 | 04:19 PM
Mangled03gmc's Avatar
Baltimore Whore
Question I know that in 05 the rods on the lq motors changed??
Over to the new style, all were the same in the engines 05 and up.. But did they also swap to a new style crank in 05 or continue to use the same as pre 05's..??? I am starting a build on a forged 370 and picked up a 02-04 lq motor with 35k on it.. I plan to make about 650 plus hp with it, want to be sure on cranks becuase I am going to use the stock one.. Thank you
Old Aug 17, 2009 | 04:22 PM
00ChevyScott's Avatar
Wearin' da big hat
I think its only the 05+ LQ9 motors, and they started using LS2 style rods.
Old Aug 17, 2009 | 04:31 PM
Baltimore Whore
Yes I know that, but did they change to a new style crank as well?? Thats what I want to know..
Old Aug 17, 2009 | 04:33 PM
Wearin' da big hat
Idk about that, but why don't you just get a complete rotating assembly from and 05+ motor and not worry about it?
Old Aug 17, 2009 | 04:36 PM
dlt76028's Avatar
no different crank that I know of.
Old Aug 17, 2009 | 04:52 PM
Baltimore Whore
Cause I already have a complete 03-04 motor sitting here.. I am selling the rods and pistons, poss the heads.. To do a forged rod, piston set up. I just want to keep the block and crank if it(crank) is the same as a 05 and after, as they went to a beefier internal set up as far as rods then the pre 05's..
Old Aug 17, 2009 | 04:53 PM
Wearin' da big hat
do a 408!
Old Aug 17, 2009 | 05:10 PM
charcold-bowtie's Avatar
ive never seen it mentioned where the crank was changed.
Old Aug 17, 2009 | 05:12 PM
StrokerAce03's Avatar
It was the LQ4 as well. Cranks stayed the same.
Old Aug 17, 2009 | 05:14 PM
Baltimore Whore
do a 408!
Negative.. 370 will be plenty
