i just ordered this cam for the lq9
what do you guys think its from trick flow?
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 228
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 228 int./230 exh.
Advertised Intake Duration: 344
Advertised Exhaust Duration: 344
Advertised Duration: 344 int./344 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.585 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer-Controlled Compatible: Yes
Quantity: Sold individually.
Notes: Computer modifications recommended for best performance
It should be a good cam. What kind of truck and what ratio ring and pinion? Stock heads? What compression?I would have gone with a little better known and proven cam but I am sure it should be pretty strong.
05 gmc sierra 3.73 stock heads for now in till i get the $money to buy some good heads
the compression is the stock lq9 10:1 i was going with the tr224 but i was talking to some guys that did some cam swaps an they all think i should go with the 228/230 from trick flow so i did lets see how it dose
can you guys help me an tell me what i should do about the tune i sill have the stock 4.8pcm but when i put the lq9 in the truck i'm going to need a good tune.
local theres only one guy as he as a dyno but it's the diablo predator tune he as the custom program that ''he'' says can due it all but hes a ford guy an i don't think i trust some one like that
any help guys
The pred is going to cut it, I don't give a **** what that guy say. I would get in touch with Dc justin) Blackbearperformance.com
or wheatley, or sombody that can get you a mail order tune..
