I have a theory (check my logic)
Old Jul 15, 2007 | 03:36 PM
ZZebes's Avatar
Originally Posted by bluecajun5.3
doesn't the L33's have flat tops?
Well here is the catch 22 about that. according to gm's Powertrain website the L33 has lower comp ratio than the LS4 but higher than the L59/LM7
and according to the overview the L33 difference is in the heads not the pistons whereas the LS4 is the piston. the L33 is nothing more than a LM7 with an aluminum block, better heads, and a better cam.
Old Jul 15, 2007 | 03:40 PM
bluecajun5.3's Avatar
11 Second Truck Club
correct.
L33 has flat top pistons with larger cc 799 heads? (same as 243's)
LM7 has dished piston with smaller cc 706, 862 heads.
that's why both engines have the same cr.
Richard@WCCH's Avatar
FormerVendor
You can do better with aftermarket pistons and rods. Not only are they stronger, but they'll be lighter and that translates to more power. You're going to have to pull out all the stops for this build. Pistons and rods are foundational items that are necessary to maximize power.
Richard
Old Jul 15, 2007 | 03:43 PM
ZZebes's Avatar
correct.
no the L33 has 9.9:1 whereas the LM7 has 9.5:1 and the LS4 is 10:1
Old Jul 15, 2007 | 03:44 PM
ap2002's Avatar
Yeah i know beau, i'm putting the bitch on a diet but i really want to go after A/P's Record of 13.2 N/A which is the extended cab record. and my ego wants to dip into the 12's which i think i can as AP ran his record on stock heads and bottom end. or i could just give up and turbo the bitch since i have a nice turbo converter in already.
in all honesty,
I would just turbo it.... you will gain alot more horsepower and it will be alot more funner to ride in it... plus with the turbo you'll be faster than that record that you are trying to go after.... I dont think that all that work that you are trying to do to break a record is really worth it... thats just my .02
ZZebes's Avatar
Richard
Yeah but no one makes an aftermarket piston and rod for a 5.3L, eagle has one but they will not sell it without the rotating assembley
Old Jul 15, 2007 | 03:46 PM
ZZebes's Avatar
Originally Posted by ap2002
in all honesty,
I know AP i picked a bitch to go after but i just like N/A power better it is always on tap and you know its gonna be there
Old Jul 15, 2007 | 03:47 PM
cool thanks for the info. i'm a lil rusty
Old Jul 15, 2007 | 04:03 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The L33 5.3L has flat top pistons and LS6 heads to make CR 9.9:1 The money spent swapping pistons/rings might be better spent on more cubes. I know you want the NA 5.3L title but how much is that worth to you?
Me personally I'd like to have the fastest street legal truck title....move over guys
Old Jul 15, 2007 | 04:40 PM
nightrunner's Avatar
Mr. Obvious
you got a ways to go, parish was street legal
but he may not count anymore since he's converting to 2wd and probably wont be street legal anymore
i think you should just try to use the L33 5.3L pistons and then mill some of the L33 (#799 i think) heads about .030 and go with that
