I guess I don't know what "NNBS" covers
Old Oct 29, 2015 | 04:18 PM
MikeGyver's Avatar
Default I guess I don't know what "NNBS" covers
I bought a 2013 Silverado intake manifold because I thought it is a NNBS, and the internet says that a NNBS manifold is the same as a TBSS manifold.
So will the fuel rails and other stuff that I can't think of from this rectangular port manifold work on a TBSS manifold?
Old Oct 29, 2015 | 04:39 PM
USMCvet0311's Avatar
I'm running a square port L92 intake on my setup and we used aftermarket fuel rails and made it a return system. When you say rectangular I'm guessing you mean cathedral.
Old Oct 29, 2015 | 04:58 PM
MikeGyver's Avatar
I have cathedral port heads and this manifold has square ports
Old Oct 29, 2015 | 05:32 PM
George C....'s Avatar
Formerly ScreamingL
Better off using what GM labels them
GMT900
Old Oct 29, 2015 | 05:34 PM
Wolftrk99's Avatar
Actually rectangular, running same intake on my 99 and you need fuel rails for that intake or aftermarket!!! The injectors go in at different spots onthe intakes which in turn moves the bolts to opposite side of the rail, if you have cathedral port heads you need a cathedral port intake.... The rectangular ports i do believe are taller than the rectangular ports....
Old Oct 29, 2015 | 05:37 PM
Wolftrk99's Avatar
L92/l99/l76/ly6/ls3 are rectangular ports ls7 and i think ls9 are square port and 4.8/5.3/5.7/gen 3 6.0 are all cathedral... The cathedral ports come to a point at the top....
Old Oct 29, 2015 | 05:43 PM
MikeGyver's Avatar
So a TBSS is not the same as a GMT900 manifold? There are no manifolds that are the same as TBSS because the TBSS is the only GMT 900 style manifold with cathedral ports?
Old Oct 29, 2015 | 05:44 PM
MikeGyver's Avatar
So if I want a TBSS manifold, it has to be off of a TBSS?
Old Oct 29, 2015 | 05:45 PM
Wolftrk99's Avatar
The 07-up 4.8/5.3 manifolds are same....
Old Oct 29, 2015 | 05:47 PM
Wolftrk99's Avatar
If memory serves the tbss had 243 heads which are being used on 5.3s now....
