Huge problems and don't know what to do!!!!!
Old Jun 6, 2013 | 09:26 AM
TXsilverado's Avatar
the moral ethics and values in this thread are through the roof! haha. how much for the roller?
Old Jun 6, 2013 | 09:30 AM
zaneregan2010's Avatar
Also this might help me with this issue. I was tunning it to turn the cats on in the truck, since I took the converters off, and we turned off the AFM so it wouldn't drop cylinders. I don't know if this cause more harm then good. But I just want to figure out what my options are.
Old Jun 6, 2013 | 09:31 AM
it would have to be 20 grand since that is still how much I owe on the truck
I made the mistake of signing a 5 year note enstead of a 3 year note like I was wanting to.
Old Jun 6, 2013 | 09:32 AM
SDPC can hook you up with everything u need to do the dod delete for under $475, probably cheaper. hell ill send u a stock cam if u cover the shipping. There is tons of info on here to do it. I say do the dod delete, put in a stock cam and roll. Whats the oil psi like out of curiosity?
Old Jun 6, 2013 | 09:33 AM
no your good on this...i turned dod off in my new 2013 w/ no problems
Old Jun 6, 2013 | 09:34 AM
See that is the other thing. Oil preasure is perfect! stays the same under throttle and stays the same at idle.
Old Jun 6, 2013 | 09:37 AM
Took it to a mechanic friend as well. We did new plugs, wire, injectors, and throttle body.
He said he wont mess with it anymore because that usually fixes a missfire, and my dad who knows more then I do said he has no idea. I'm just completly speechless on what to do with it.
if i were you, i would start with changing your oil and cutting open the filter and see if any metallic particles are in it. IF i remember correctly, GM had some issues with the older NNBS
lifters.
Old Jun 6, 2013 | 09:39 AM
sounds like a lifter/cam issue. DOD delete, new cam/lifters and be done with it!!
Old Jun 6, 2013 | 09:41 AM
nonnieselman's Avatar
yea i would surely take it apart and see whats goin on before you put a 4.8 in it and screw somebody over.
owing 20k on a 2009? is it a LTZ?
